Troubleshooting Horn (not honking)
Old 01-14-2018, 03:08 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
The hardest part of removing the column is the Unijoint at the firewall. the column at the wheel end is held in by 2 bolts. IIRC you do need to remove the instrument cluster.
JimJam (01-14-2018)
Old 01-14-2018, 03:33 AM
JimJam's Avatar
Warrjon
Thanks for the additional information. I have a Haynes Repair Manual that I will read in the hopes of being able to perform the task at hand.
Thank you for your quick response and feedback
JimJam
Old 09-01-2021, 09:34 PM
Pawsnclaws's Avatar
What's the spec for the horn relay on a '91 XJS? Mine was removed sometime in the past and a yellow wire plugged into the holder (as a jumper, I presume). Now, I need the horn to work, and figured I'd start by reinstalling the relay. But what relay do I need?
Thanks,
Pawsnclaws
Old 09-02-2021, 12:13 PM
ptjs1's Avatar
Received 3,094 Likes on 2,042 Posts
The horn relay on a facelift XJS is light blue which is the same as many of the relays, and the same as the other ones in that relay set of the RH inner wing.
Paul
Old 09-02-2021, 03:37 PM
malc4d's Avatar
Paul. As he is in the USA, l believe his car is a "90 pre facelift model.
ptjs1 (09-03-2021)
Old 09-02-2021, 03:39 PM
Pawsnclaws's Avatar
Mine is one of the last pre-facelifts. Still a light blue relay?
