turn signals inoperative
RE: turn signals inoperative
Woodburn, not sure if their the same, but on my 95 XJS, on the drivers side, pull the panel under the steering wheel, look for a bracket holding several relays. Mine relay is Black on a yellow base. If you lights come on when you move the turn signal stalk, you may be able to hear, or feel the relay when the lights come on. As I understand it, there just not flashing like they should. Hope this helps. Keith.
Malihide
04-02-2016 04:05 PM
Richard_gib
09-12-2015 07:08 PM
