Turn Signals are out
Then came the redundant ground. I fashioned 2, 6-8 inch long pieces of wire. On one side of each wire, I crimped a spade connector. On the other side, one wire got a male connector, the other a female (as shown). One wire got bolted to a solid ground point on the car, while the other, a solid ground on the cluster. Then i reinstalled the two factory plugs, plus my additional ground wire.
I would use 18 Gauge.
If you do not have the electrical guide for your car you can download it here.
http://captainjaguarscathouse.com/El...ec%20Guide.pdf
I would download the guide. Then find every ground point in the car. Take it off and clean each of the ground points for the entire car. These need to make good contact. Then clean the printed circuit board connector and add the extra ground to your cluster circuit.
Are you having trouble reading the wiring diagram?
You need to learn Russian.
Anyway the link I posted has a page with all the ground points. Start by cleaning those. ALL of them. This will take you a while but will be worth it.
ok, so we have progress! After much poking and proving of the hazard button, the turn signals work now. However, the driver side blinks normally while the passenger side blinks like a maniac. As soon as I can figure out how to pry out the switch, I'll replace it with another hazard switch I acquired.
Malihide
04-02-2016 04:05 PM
Richard_gib
09-12-2015 07:08 PM
