Turning V12 over by hand
I recently got a 76 V12 project, non running (despite you guys recommending otherwise, but I really just wanted a minimal-worry project).
First order of business is turn it over by hand, but I'd like advice on how to get to the hex on the pulley. I have the one-bolt fan clutch, and that whole assembly isn't coming apart.
What would be the best way around this? Can I somehow remove the fan/clutch? With the clutch stuck to the shaft and fan pulley housing, it's too big to just take out.
Do I really have to remove the radiator for this? Or, is it possible/easier to remove the fan shroud and fan assembly while keeping the radiator there?
Those older single bolt hubs grow to the snout of the fan bearing unit.
Mix up ATF/Diesel Fuel, in a 50/50 BREW, and squirt/spray/drop some in that area, and WAIT, soak it at each stubby change, and it will come off.
Under the front for access to that hex is doable, and as said DO NOT rotate that engine backwards.
Thanks for the suggestions guys.
I'll have to try again with a wrench from under and see if I can get enough leverage. I did get it to go a few degrees with a breaker bar but then I ran out of room. It feels tight for sure but not stuck, so that's good.
Barring all that, I may have to go with baxtor's suggestion to take the shroud off with the fan, or keep soaking the clutch.
I expressed myself a little badly... You'll hear and feel but you shouldn't have a feel like when turning a 4 cylinder where you get a compression stroke and you notice it... A V12 always has one cylinder compressing, so the force required to turn the engine over by hand is nearly constant.
The following 2 users liked this post by Daim:
Andreas Schmieg (01-23-2018),
ronbros (01-23-2018)
Got it with the wrench! Thanks guys, not really sure why I didn't even try that in the first place. I looked from under and it looked so cramped so I just mentally checked it out.
Turned pretty smooth 720 degrees. Next up is to try cranking it (already put a bit of oil in the cylinders) and then do the compression test.
Greg
If I have to pull the engine though I won't be too heartbroken, I'll have to excuse to take everything apart and learn as much as I can. And also go straight to a manual swap since it's out.
FS[Australia]: Left Hand and Right hand Front Door Latches
jya
04-29-2016 08:31 AM
richzak
10-29-2015 08:22 AM
macksjaguar
01-28-2012 04:52 AM
