Twin Turbo V12 project.
#221
Facinating information guys, thank you.I have a 5.3l 1988 Xjs called thunder. Alu flywheel and match to a 4 speed manual xj gearbox. Im seriously considering boosing her for power as the cost of getting power out of her in NA form seems extreme relative to the returns.
the 2.0 subari pistons sound like the way to go....I have engines and access to my own workshop, but i would appreciate any assistance with information to avoid costly trial and error r&d....Help
#222
1st
Few actually know that much about fuel injection, while they can discuss things knowledgeably they’ve never actually worked on it ( including a fair number of mechanics paid to work on our cars) and that lack of knowledge combined with wrong information on sites like this scares and confuses them. They want simple plug and play solutions. They think putting carbs on is that plug and play sort of solution.
Carbs do not work well with turbo chargers.
2nd
Unlike most modern cars, most systems on Jaguar V12’s are not digital. They are analog. Including, especially including the sensors. Adapting sensors or getting the ECM to speak analog is really difficult.
3rd. Even systems with self learning capabilities ( Mega Squirt) cannot achieve perfection without input from your laptop while you drive. While it is possible to adapt the later distributor less ignition system to fully develop the potential of the V12, there would be thousands of man hours expended to achieve what the factory did. Plus you would have a car unique to others. Not necessarily better. Plus one without shop manuals to guide future owners how to tune or fix.
The factory took 21 years to develop the fuel injection system for our XJS using the most advanced technology available. Yet even the newest is more than 25 years out of date and took ideas out of Ford’s parts bin that had already been superseded. It is at least 6 generations outdated.
While it can be done for racing, racing is far less complex than street driving. Especially when fuel mileage or pollution levels isn’t a factor.
Bez74 (03-22-2020)
#223
Ferrari, Aston Martin, etc etc etc all went to side intake. It’s easier to get equal length in the plenum with side than front. Plus the V12 is long, add a intake to the front of it?
#224
My goal is to have an almost totally stock looking XJS, albeit with wider wheels under standard rear guards. So there are no bonnet mods in my plan, maybe vents similar to XKR. A Turbo install I think bonnet vent are a must to get the heat out otherwise there will be heat issues. We have 3 TT XJS here in Aus and ALL of them have vented bonnets.
So I am planning a centrifugal supercharger. I initially wanted a Whipple (but not 2) and getting this under the bonnet was almost impossible without major surgery.
The V12 has an abundance of torque on hand from quite low RPM so I think the CF will work. Lister used 2 CF Albrex superchargers on the Lister XJS MKIII and made 700hp.
A SC install will provide smoother power delivery than TC. If I can manage a single SC it will simplify installation. No exhaust mods needed in a basic install.
I think it can be done with one and a small splitter type manifold to each plenum. A W2A IC can be incorporated into the splitter.
So in a nutshell if I can engineer a single SC installation
Located in place of the idler pulley/air pump.
IC 1 input 2 outputs could be A2A or W2A
Ignition options dual Ford EDIS or GM Delco (will require removal of distributor)
ECU?? Dual Delco 808's or aftermarket
cheers
Warren
cheers
Warren
So don’t put the turbo’s there. Tuck them under the front fenders behind the tire. One on each side. I know T2’s fit. I’ll have to check on T3’s.
with regard wider tires. Back in the 1980’s JaguarXJS in Group A touring car used 17x10 inch rims without changing the fender line. It also allowed 14 inch brake rotors.
