Tyre Pressure ?
I just checked mine and I've got 35 in the front and 36 in the rear. Due to weather, that's probably an increase from whatever I set the pressures at last time I messed with them a couple of months ago. I haven't fine tuned my tire pressures through experimentation like I have with my other car, but what I'm running now seems to be working just fine for now. I'm running 225/60R16 Kumhos on mid 90s eleven spoke 16x7 wheels.
Duke85 (05-30-2020)
The guide book for my '90, 3.6 manual on 15 inch tyres says 34(F) psi and 36(R) psi but can reduce by up to 8 psi for maximum comfort for speeds < 100 mph. As I don't get above the ton much these days(!) I have been using 26 / 28 but I might experiment with higher pressures now.
What do others use?
Cheers,
LeeP
What do others use?
Cheers,
LeeP
