Uh Oh!
Coil is new, resistor pack plug checked and cleaned, swapped out with known good ECU, vacuum advance working, cap/ rotor checked, mech advance springs back good, fuel flow out of surge tank good, plugs good a gapped, magma vote wires, all sparking, coil spark super hot/blue. Revs good P or N, idles like crap N or P, chugs in D or R. Same way it ran last March, though it was the CTS connector. Got a spare TPS, may swap that on.
Ok, swapped in another coil...same.
Put on another TPS....same
Mounted another spare ECU....same
Cleaned FI harness ground and multi plug....same
Cleaned resistor pack plug again...same
I've already swapped out ignition AMP...same
Vacuum connection to ECU is good.
Need to get a sample of gas from the tank bottom to see if it's contaminated with water. It ran like a top before doing the down pipe removal/replacement.
If you're getting good spark, then you may be running out of fuel. Maybe you inadvertently pinched the fuel line while jacking up the car? I think the vacuum line to the ECU is in the same vicinity. This could cause a similar problem. If it was running nice before the project and isn't now, I'd think you should focus your efforts in the area you were working first and make sure everything is good before widening the search. However, there is a small chance this is coincidental.
Changed to a new ATS and pig tail tonight, still the same, backfiring out of exhaust at idle and no power/stumbling in drive or reverse.
Ive been following this thread with interest. Doug gave a good extensive list of item to check. Sometimes it's easier said then done. It's seem likely fuel related since you have good spark. My procedure at this point is to get a small squirt bottle and put some gas in it. Remove the air filter and while it is running squirt some gas into the throttle body. If it smoothes out and rpm increases that bank is likely running lean. If it causes it to stall or idle worse it is probably not lean and could be rich. If you believe it may be rich open a vacuum port to add air. See if the idle increases and becomes smoother. It's not an absolute diagnosis but may give a direction to look. Careful to have a fire extinguisher handy.
Jonathan-W (01-06-2016)
#28
Hmmmm, idle changed some when I pulled the "B" bank FPR last night and I didn't like the looseness of the vacuum elbow on it. I went out today to change the elbow and try a few other things on the car and the elbow was full of fuel, so I do know that Fuel Pressure Reg is bad and could be the culprit or a contributing factor.
Greg
Jonathan-W (01-07-2016)
#30
#31
#32
Greg
#33
What a sod. On my post number 20 above, can you tick off what you have done and let is see what is left? Either fuel or spark is breaking down at higher revs, just got to eliminate possible causes one by one and find out which and why. Courage as my French mates say! Greg
replaced coil
Checked all amp/coil connections
Replaced ECU
replaced TPS
Replaced CTS and plug
Replaced ATS and plug
Replaced fuel filter
All injectors clicking as it idles
Good fuel flow out of surge tank, pulled gallon of fuel out, no water or debris
Checked all vacuum connections.
New O2 sensors
Cleaned FI resistor plug/connections, checked FI harness/ground
Checked AMP coaxial
Problem isn't high RPM break down, it's idle, back fire popping and stumbling in D or R. In N or P if I run the RPM's up it runs fine. If I pull the vacuum from the left FPR it seems to smooth out, increase idle some.
Going to pull the distributor cap today.
#34
#35
Greg, once it's under load it's runs like crap, it only runs smooth in higher revs in P or N. Letting it warm up makes no difference.
#36
Replaced ignition AMP
replaced coil
Replaced ECU
replaced TPS
New O2 sensors
Checked AMP coaxial
replaced coil
Replaced ECU
replaced TPS
New O2 sensors
Checked AMP coaxial
Of my Post no. 20 list it seems you have done/not done as follows:
- Checked/replaced dizzy cap and centre graphite electrode NOT done
- Replaced HT leads and plugs (correctly gapped to 25 thou) NOT done
- Checked dizzy spindle is not jammed and springs back when turned NOT done
- Checked/replaced dizzy internal pickup, starwheel condition, and condition of twin wires from dizzy bottom to the amplifier side plug NOT done
- Checked vac capsule is functioning as it should NOT done
- Checked connectors and wires to coil + and - (wires can fracture within the OEM connector rubber covers) Done ?
- Checked for a big powerful blue spark at the plug end of the HT leads NOT done
- Checked ignition timing? If so how exactly did you do it? NOT done
- Checked and cleaned injector resistor pack plug and socket Done
- Checked loom to coolant temp sensor on B bank thermostat casting NOT done
- Tried replacement CTS. Done
- Checked that CTS and air temp sensor plugs not accidentally swapped NOT done
- Checked the first foot or so of the shielded wire from amp that leads to the ECU. That is strip and ensure the inner wire is NOT earthing to the shield. Check that the shield is earthed to the loom at the amp end of the wire. Done ?
- Check you have not put a screw through the firewall low down (eg to secure the US passenger side front wheel baffle). This can hit the loom to the ECU which is the other side. Done ?
- Checked injectors are pulsing and flowing the correct amount of fuel when fitted to the car NOT done
- Checked the injector pulses are quickening when the car is revved Done
- Checked fuel pressure in the fuel rail NOT done
- Have you verified the vac line from the tapping at the centre of the cross pipe across the rear of the motor that balances the two intakes and ends up at the ECU will hold vacuum? NOT done
- If you remove a vac pipe that goes into the inlet manifolds (eg gearbox modulator, crankcase breather sprung thingy on B bank air box, or any other capped off inlet manifold spigot) does the car rev up? NOT done
Greg
#38
The following 2 users liked this post by JTsmks:
Greg in France (01-26-2016),
Jonathan-W (01-26-2016)
#39
