UK breakers/ idler pulley assembly
Old 12-29-2017, 07:06 AM
BradsCat's Avatar
Default UK breakers/ idler pulley assembly
All UK friends,
Several weeks ago I posted a request for assistance on a supplier source for the Idler pulley assembly that is used on UK version cars. I am wanting to take the US version anti-smog plumbing off of my car.
I was given the name of an Andy Harvey with XJSPARTSLTD and he did respond to one e-mail about 3 weeks ago but nothing since then.
I have a friend who is traveling to the UK for a 10 day visit shortly and will bring the parts back to me saving a lot of money on shipping costs.
The person she is visiting is coordinating for the parts delivery. he will assist with the parts but has not been able to contact Andy Harvey.
I am now looking for an alternate he can contact for assistance with the parts acquisition. Thank you
Brad VA
Old 12-29-2017, 07:08 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Simply Performance is a good address for parts like that.
Be prepared to buy a new bearing though! Mine was 28 years old and really nasty (my original one!). A new one costs something like €100 (so like $110 or so).
BradsCat (12-29-2017)
Old 12-29-2017, 08:17 AM
BradsCat's Avatar
Thanks, I can probably get a new bearing from a local machine shop here in the US for about $10. Somethings are better here, others not so much.
I think getting rid of the air pump plumbing will clean up the aesthetics on the top of the engine. Of course this project is only after I get the instrument panel and center console and new wiper motor back re-installed. Also have to address to electrical issues with some of the parking and turn signal indicator lights on the front. Hopefully I can work all of these issues worked out in fairly short order and have the car completely road worthy in the next several weeks.
Old 12-29-2017, 08:38 AM
Daim's Avatar
Erm, no. The bearing for the pulley is again a special Jaguar bearing. It is like a water pump bearing, just with a locating ring on top and a groove all around it. The shaft also needs to have an end piece pressed on in order to take the pulley itself. Been there already mate
You can probably get a custom one made but then it would be easier to get an entirly custom made bracket and adapter...
Old 12-29-2017, 08:42 AM
Daim's Avatar
Here are a few pictures up close to show how it properly looks...
Old 12-29-2017, 08:50 AM
44lawrence's Avatar
Someone on one of the Forums showed how he made things work with standard size sealed bearings. I don't remember when or what Forum it was on but it was a while back
Old 12-29-2017, 08:55 AM
Daim's Avatar
Yeah, I remember seeing that as well. But then he also made a totally custom housing and shaft.
Old 12-29-2017, 09:59 AM
BradsCat's Avatar
It looks like the bracket above the coolant crossover pipe may be the same as is used on the anti-smog air pump setup. If so I don't need that.
It's amazing to see how much room is opened up with the air pump out of there. It looks like you actually have easy access to the alternator.
Old 12-29-2017, 10:00 AM
BradsCat's Avatar
Anymore details on where Simply Performance is located, address, etc....
Old 12-29-2017, 10:09 AM
Daim's Avatar
http://simplyperformance.com/
That is their homepage. Contact Ben for best superior help...: ben@ENTER THEIR DOMAIN HERE
I have found no problems when dealing with them. If I had, I would not recommend them.
Old 12-29-2017, 11:03 AM
brinny's Avatar
I would think simply performance would be capable of sorting you out. Where is your uk contact based out of interest.?
Old 12-29-2017, 11:27 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
The bracket for the idler pulley is NOT the same as the air pump bracket, Brad.
brinny's Avatar
Have a look on eBay uk. I believe there are a couple of options on there.
Old 12-29-2017, 11:28 AM
The bracket for the idler pulley is not the same as that for the air pump, Brad.
Old 12-29-2017, 11:39 AM
Jagboi64's Avatar
Received 3,145 Likes on 2,080 Posts
Canadian V12 cars prior to 1988 didn't have an air pump so if you could find one at a Canadian junkyard that might also be a source. Probably would be a sedan, rather than XJS, but it was the same pully as far as I know.
Old 12-30-2017, 01:09 PM
Simply_Performance's Avatar
Hi Brad,
I am Ben and I run Simply Performance. We will be able to assist you on the part. We can supply you one with the bracket complete.
There is a contact form on our website www.simplyperformance.com
Thanks,
Ben
Old 01-16-2018, 08:12 AM
BradsCat's Avatar
My friend returned from her trip to England with my idler pulley assembly in tow and the Rushton Engineering head plugs. Once it warms up a bit I'll be pulling all the US edition anti-smog plumbing off the car. I think it will clean up the engine bay a bit. Nothing dramatic but a nice subtle change.
I decided to go with the Rushton Engineering plugs even though they were a bit pricey because I didn't want to fabricate something on my own. I know others here have done so but it was just something I didn't want to mess with personally.
The following 2 users liked this post by BradsCat:
Daim (01-17-2018), Greg in France (01-16-2018)
Old 01-17-2018, 02:37 PM
Daim's Avatar
Good luck Brad! Does the bearing have slack? It is still available new
Old 01-17-2018, 03:41 PM
brinny's Avatar
It wouldn’t have hurt to reply to some of the people on here who were responding to your request for help .
Old 01-17-2018, 03:42 PM
brinny's Avatar
It wouldn’t have hurt to reply to some of the people on here who were responding to your request for help . Courtesy I think it’s called.
Quick Reply: UK breakers/ idler pulley assembly
