Under bonnet (hood) temperatures
Old 08-23-2016, 06:36 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
Originally Posted by warrjon
Your ECU should support IAC, check with the manufacturer if it can support PMW IAC, then use any Ford IAC valve. You would need to fabricate a mount.
Or simply change the AAV for a manually operated butterfly and have an old fashion choke
YES Warrjon my standalone ECU SDS(simple digital systems) has a pin with tempeture adjustable digital output, altho its either on or off.
i think it would work,with a relay ,for what i need, just trying to find the right part, seems many options out there!
i could also have a manual over ride switch, for extreme situations.
  #82
Old 08-23-2016, 07:05 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
I just had a look at the SDS fast idle.
It uses a Ford IAC solenoid and a restrictor to control idle speed. As a restictor you could use a pipe with a screw to vary idle speed.
ronbros (08-24-2016)
  #83
Old 08-23-2016, 07:50 PM
Jagboi64's Avatar
Received 3,169 Likes on 2,094 Posts
If you want to go simple you could use the thermal unit off a Series III XJ6. Not as tunable as something ECU controlled, but seems to work well enough on the XJ6.
  #84
Old 06-28-2019, 05:46 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Learning learning learning, here...
You all have so so much wisdom & experience.
Thank you!
