under hood fuse box
its on the left buy the reinforcing strut mount, it has 5 glass fuses in it for lights,
Ohhhh!!! I think I better understand your troubles now. Sorry. There are things. I found this...
Check this out at Amazon.com
EEFUN 6 Way Car Standard Blade Fuse Holder Box (Apply to 1~40 AMP), Block with 10pcs Free Blade Fuse (3A/5A/7.5A/10A/15A/20A/25A/30A/35A/40A), Auto Fuse Block for Car/Boat/Marine/Trike
rgp (08-15-2019)
Rex
I think you will have to buy an aftermarket fuse box and fit it. The problem being attaching the loom to it, as there is no spare length under it to work with, so there would be a bit of joining etc etc required. If you want to keep the OREM look, then I reckon you could gut an aftermarket one and fit it into the OEM holder. I recently tarted up my electric fan wiring, and this is what I fitted for the various fuses:
rgp (08-15-2019)
Received 10,990 Likes
Might be easier to repair the existing fuse box? Just a thought.
Another thought:
For (USA) 1988 model year Jaguar dumped the glass fuses and went modern. I'll wager a fusebox from a later car would drop right into place, eliminating at least any mounting issues. Plus the wire colors and fuse locations would probably be the same.
Another thought:
The following 2 users liked this post by Doug:
Greg in France (08-16-2019),
rgp (08-16-2019)
OOPS, mine did that 20+ years ago, and since I was renewing ALL the headlamp wiring, and adding relays for them, at the time, i went with thermal circuit breakers, and simply combined some circuits on the one breaker.
This is the only snap I have, and I made an alloy cover, powder coated and fixed with the 2 OE bolts.
Never went in there again.
The following 3 users liked this post by Grant Francis:
