Unidentified objects
Hi C&P
As has been already said, just send the seller a message to say that its the wrong one for your Car
And they will almost always be ok with that
Especially if it says returns accepted
All you are really going to need is the Hook for a Full Size Wheel as you should be able to use the Nut off your Broken One
But just to be sure give Jaguar Classic Parts a ring and ask them if both types have the same Thread Size
Maybe one has got a Steel Nut, like on your Broken one
While the other type might have the plastic Hand Wheel
In which case you would only be in for £23-76 providing that delivery is included?
Did you look at the link to Jaguar Parts I posted ???
Your pic shows the correct part for the normal spare but the end is broken off. You need the part CCC 5673 with your part (nut) CBC 5627 for the full size spare. Its available from Jag new for around $35.00
Keep the link to Jaguar classic parts handy. It will help you out nearly everyday .....
Update on the Ebay item: I did send the seller a note and see that he canceled it ...pheww!
The following 2 users liked this post by carsnplanes:
davidboger (01-22-2018),
o1xjr (01-21-2018)
Wouldn't we all like to know!! I will share when I finally get it open. Kind of a Pandora's box!
It's secured/screwed to the trunk floor so I cannot even remove it from the trunk to bring it anywhere to try to open.
ericjamiesonxf
03-12-2022 04:13 AM
JaguarXJR02
05-18-2013 09:11 AM
