Unstable Idle (Not AAV issue..)
Good afternoon guys, interesting problem with my 94 V12 XJS. Ps. do not look at Temp gauge, due to angle of the camera it looks incorrectly.
Couple issues:
1. With Hot engine (Mostly) - idle is not stable (As seen in the movie) - it kind of stays on ±750 rpm but suddenly goes down to 500 or lower, tries to stall but then comes back to ±750. No vacuum leaks (All hoses and connections new), most of the sensors are new, throttle gaps are 0,05, new throttle bushings and AAV was recently refurbished (Maybe incorrectly?), all new fuses and switches.
2. FF44 is always there.. new 02 sensors, cleaned all Earths, new additional earth attached to AAV as suggested in bulletin, no exhaust leaks as well.
3. With HOT engine it's not possible to restart/start the car once more. Only after 2nd,3rd crank it starts up. While with cold (in the morning) it starts absolutely fine from half crank. (New battery, AC working);
Overwise Car drives and runs smoothly and really strong.
Any help would be more than welcome.
Gracias,
Couple issues:
Gracias,
I would suspect your coolant temp sensor, very inexpensive part and often worth replacing just because.
Here is a link on how to test it:
Testing the Coolant Temp Sensor
Grant Francis (08-25-2021)
My experience with 6ltr cars is zero.
One only here where I call home, and I have never seen the bonnet open.
BUT
On the 5.3 cars the EFI Power Resistor Pack, located RHF corner on the engine bay on those cars, has a multi pin plug inserted from the bottom. The crud, along with old age, creeps in, and HOT starts are a mongrel.
2 hex screws hold it to the inner guard panel. Remove them, twist it around for access, unplug that Multi Pin, and clean the plug and the socket. I use Lemon Juice (the real stuff), and rinse off with WD40 or similar.
That simple process has revived many a V12 for me over the long years with them.
Another FREE thing.
Clean the face of the 2 Crank Sensors. Front one and Rear one. They are a magnet after all, and get very grubby, and that causes all sorts of havoc. Cleaning that sensor on my X300 (only has one) restored sweet running.
BUT
Another FREE thing.
Greg in France (08-27-2021)
