Urgent!
Urgent!
Left the dashcam plugged in for a week while gone, power locks won't open the trunk to get cables on the battery. What can I clamp to in the engine to get power just to do get the lock to move? Is the red cable/bar that the starter cable bolts to is good for + ? and negative is anything on the body?
Yes, the starter is +, as are the terminals on the firewall and the body or engine block is ground. However, you should be able to get in the trunk with the key. My 94 lets me in the trunk with the just the key when I have removed the battery for the winter. I think the procedure is turn either right or left ( can't remember) then move the key back to the middle, vertical position and the latch should unlock.
vennala@lycos.com
05-20-2008 06:10 AM
Cush
04-29-2008 02:07 AM
