v-12 coil wires
My electrical wiring manual shows the upper coil, "B" feeds the left bank "B" which is the off-centre plug on the distributor and the centre plug feeds the "A" bank from the lower coil. Of course, you have to connect the correct low-voltage three-wire connectors to the appropriate coil also, although the coils are identical, so you could feed them both the other way round and the engine wouldn't know the difference.
Good luck, Michael.
Good luck, Michael.
