V stem seals
Guys
Advice and opinions please. When the brave day comes that I rebuild my engine, all parts having been gradually accumulated beforehand, I want to be as clued-up as possible.
I have been finding out about valve stem oil seals, and there are a variety of materials used, apparently:
Greg
- OEM nitrile seals - these fail after a bit apparently.
- Viton seals - this is a more durable material, FelPro make them, but I do not know if they make a size suitable for the 5.3 V12. Neither do I now if a Viton seal is thought to be good material to use in the V12, if they can be found.
- Teflon valve seals as recommended by the Great Palm. Apparently part number DT1610 fits.
- Lastly, although no seals are fitted to the exhaust valve OEM, Viton and Teflon seals are alleged to stand up to the heat, so is fitting a seal to the exhaust valve stem recommended?
Greg
Received 1,442 Likes
Hello Greg. I will jump in on only the final question . . . efficacy of fitting stem seals to exhaust valves . . .
Back in the day, and I admit this is at least 20 out to 35 years ago, despite universal use of inlet seals, it was considered of no use whatsoever to fit such seals to the exhaust valves, whether for road or track or in our case, on "Jagged" our unlimited twin turbo'd V12 Jag hydroplane. Reasons were backed by plenty of experience . . . seals are all about inhibiting cylinder negative pressure from drawing excess oil into the combustion via inlet valves.
So,even in "blown" engines, provided exhaust valves were well lapped to their seats, by the time they were opening, even with competition camshaft overlaps, the cylinders had positive pressure so oil was never going to be drawn into cylinders . . . making any exhaust seals totally redundant.
Sorry I can't provide any reliable knowledge of relative merits of materials for inlet seals.
Cheers,
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
Cheers,
Ken
The following 3 users liked this post by cat_as_trophy:
Greg in France (04-05-2018)
Do you have a part number or a maker ? I am a bit more inclined towards Viton as thye are meant to be a bit more forgiving and easier to fit than Teflon ones.
Greg
Greg
cat_as_trophy (04-05-2018)
Agreeing with Ken, or rocks will land on my roof from afar.
I used OE and did the Inlet only.
I always liked a little "lube" down the exhaust valve stem, they do get a tad HOT.
No seals on the Inlets will suck the sump dry eventually, and make a hell of a mess.
Then,
My totally Non-Scientific reasoning behind what I did.
1) Jag only supplied 12.
2) "Oils Aint Oils", and the current spec oils are kinder to all sorts of non-metallic components, stem seals included.
3) I have the cooling system well sorted, so the engine, and its oil, do NOT get out of temp range, ever.
4) The V12 cam shaft area is significantly "drier" than the older XK 6 cylinder engine, which basically bathed the cams and buckets in oil.
Then,
The following 3 users liked this post by Grant Francis:
Then,
Then,
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
ronbros (04-07-2018)
Yep, they have survived 30 years and NO issues, so in the next 30 years, YOU and ME will be looking down from the Jag place in the clouds and laughing our aarses of.
PLUS
The egg timers up there move at half pace, so we will be too busy.
Greg in France (04-07-2018)
That $600 chain tensioner will need "fiddling" with to get the cams off, not for the feint hearted.
Then the risk of dropping a valve into a cylinder is right up there with BUGGA.
Stem seals on a V12 are not a known issue. Most all oil smoke is from driving too sedately, drive it like ya stole it, perfect the V12 grin, and move on.
Grant Francis (04-07-2018)
Nope.
Doubtful.
More likely oil coming up past carbon jammed rings.
If it were 5 or 6 then maybe stem seals, as that is the hottest part of the engine.
Our HE engines are the Hi Comp units at 12.5:1 ratio. Lack of use at some stage of its life could also be at play here.
My PreHE's do oil up #3 on each side, but a decent redline blast for a few hundred kms takes care of that for a year or 2. Our stupid 50KPH speed limits are very V12 unfriendly.
The HE's never did, and I did find the Red Devil had seriously stuck rings when I pulled it down for oil leaks, oops, and that really surprised me due to it not burning any oil, just leaking it. The original owner used it in and around Adelaide only, never drove it as designed, so not surprised at all by what I found. The stem seals were still very pliable, and the stem to guide clearance quite good, but it got new valves anyway.
Maybe a good hard run will help it sort itself.
I'm rebuilding an ex USA V12 ATM and from what I've seen every valve stem was elliptical and every spring not straight.
The following 2 users liked this post by warrjon:
Grant Francis (04-17-2018),
Greg in France (04-16-2018)
Received 1,236 Likes
warrjon , there is a way to use compressed air to pressureize the cylinder with piston at top of stroke, done that CAREFULLY a number of times !!
there is also a kit available , Summit racing or some such,
i used a fiddled together air hose and adjustable valves ,with gages to measure pressures! screwed into the sparkplug holes!
ron
ron
ron
Greg in France (04-17-2018)
ron
ron
Grant Francis (04-19-2018)
