v12 A/C ports
Working on my '87 XJS V-12.
I am converting the A/C to R-134. I bought a port conversion kit from the local auto parts store. The high side port adapter is fine. The low side seems to be a no go. I took the schraeder valve out of the low side port to be able to screw on the new adapter but for some reason it is not connecting. Try as I might it just won't connect up with the threads on the original port.
The low side port adapter is about 1 1/2" long and has a schraeder valve already in it.
Is there a special connector adapter for these I need to find?
