V12 differences?
Old 06-17-2010, 10:06 PM
JameyXJ6's Avatar
Great info!
I think I found a suitable replacement low mileage 5.3. I'm hoping to go pick it up next week.
It came out of an 86 that had an electrical meltdown. The engine is good, but the injection system is gone. I'm pretty sure the parts from my 83 will fit but please correct me if I'm wrong!
Old 06-18-2010, 06:34 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
If you can not hear it running be wary or make sure you get a warranty. These engines are pretty bullet proof the only that kills them is overheating and most commonly this causes dropped valve seats. The symptom is ticking that gets louder with revs. I haven't heard it myself but I have been told is quite audible.
The ignition system should be the Lucas constant energy this was fitted to the XJS between 82 and 89.
Before you you go buying another engine why don't you pull it down to see what the problem is if it is just rings foe example it might be more cost effective to just buy the parts, just a thought...
cheers
Old 06-18-2010, 07:16 AM
JameyXJ6's Avatar
I was going to pull it out and pull it apart, but this guy is selling the motor cheap. If nothing else I'll get it for parts.
I'll post more once I get it home and can check it out better.
Old 06-18-2010, 07:34 AM
warrjon's Avatar
If its that cheap I would say go for it you can always keep the leftovers for parts
Old 06-19-2010, 07:06 PM
JameyXJ6's Avatar
My thoughts exactly!
Old 11-03-2011, 05:14 PM
M90power's Avatar
good call on putting oil in the cylinders. ive had a couple of older engines, especially engines with water in the oil that have frozen up from dry cylinder walls. oil or diesel works pretty well.
JWheeler
11-22-2019 08:28 AM
Doug
02-27-2019 01:31 AM
Ozzy_UK
General Tech Help
01-14-2016 02:52 PM
prettydaim
09-10-2015 04:27 AM
1100me
09-07-2015 06:26 AM
Quick Reply: V12 differences?
