V12 Engine Designers Walter Hassan And Harry Mundy Video From The Archives
Hi Guys
I've just come across this Video from the Archives, which some of you may not have seen before (In Black and White)
Where V12 Engine designers Walter Hassan and Harry Mundy are being Interviewed by Raymond Baxtor
Who seems to be remarkably well informed
Where you can also see the workings of the Timing Chain Tensioner as well as the Opus Ignition System
Which could be very useful if anyone gets a problem in that area and could have done with seeing that myself when I thought I'd broken my Timing Chain Tensioner
And could provide some interesting points for a discussion
I've put a similar copy on my 'Cherry Blossom' restoration thread, where when I've had a look at my notes from back in the day
In between I hope to continue my journey to the ownership of my very first XJS Convertible
Mkii250 (12-09-2017)
What is meant by neat fuel is liquid fuel ie not vaporized. Liquid fuel does not burn, it washes the cylinder walls cleaning the oil and increases cylinder and ring wear.
It has nothing to do with octane rating.
Octane really depends here in Aus pre-Marelli cars were setup to run on 91RON 89MON for Americans. Marelli cars have a strategy link allowing either 91 or 95RON.
Our pre-Marelli cars were listed at 284hp on 91RON.
xjs1988 (12-09-2017)
So people out to stop worrying about ethanol. Petrol is more hazardous.
Received 10,871 Likes
The following 4 users liked this post by Doug:
The following 5 users liked this post by Greg in France:
Doug (12-09-2017),
Grant Francis (12-09-2017),
orangeblossom (12-11-2017),
warrjon (12-10-2017),
"My brake pressure regulator is dead! Only because of E10!"
"My camshaft snapped in half! E10 is to blame!"
"My seat has torn! E10!!!"
I simply say: any fluid or even vapor which can be ignited with a spark will run in the engine and the engine won't take any harm. But then come the experts who will say "you can't burn hydrogen in an ICE because it will disipate through the walls because hydrogen has a smaller atomic mass and size than iron/steel molecules do and blah blah blah"
Ethanol will perish rubber, most cars for a very long time have used neoprene seals so no problem with E10 in these vehicles, here in Aus that's probably vehicles manufactured before 1980.
The biggest issue with Ethanol fuels here is water, there was a spate of expensive vehicles sidelined with water in the tank after filling up with E10 then filling with neat petrol.
E10 is hygroscopic so will retain water until you add regular petrol then the water can not stay suspended and drops out.
The following 2 users liked this post by warrjon:
Greg in France (12-11-2017),
Jaguar Forums Editor
Jaguar Press release
07-30-2015 02:18 PM
