V12 flex plate removal
The V12 flex plate is bolted to the crankshaft. In addition there are two inserts for the bolts holding the "bar" for the nut used to twist the crank by hand. these two inserts are holding the flex plate onto the crank shaft, or so it seems. Any idea how to release the flex plate?
Yep.
1) Find some long fully threaded bolts (we call them set screws) that fit the threads, and NO, my memory is simply not that good.
2) Find something to slide between the crank flange and the cylinder block, I used a piece of wood.
3) Thread those bolts (setscrews) in and slide the wood in, and keep winding. The end of the bolt/s will contact the wood, keep winding, the thread thingy will come out. They will be TIGHT, so patience will be your friend.
There may be other ways of doing this, but that worked for me many times.
1964Daimler
09-09-2015 11:28 AM
