V12 fuel pump fuse ?
Hi Rowland
Have you checked the Fuel Pump cut out switch by the door pillar?
Fuel Pump Cut Out Switch by Door Pillar 'push button in top to reset'
It could also be a problem with one of the Relays, so do a Test and see what you can find, this is on Page:46 of my 'Cherry Blossom' restoration thread 'Click on the Link below'
How to Test the Fuel Pump Relay on a Pre-Facelift XJS V12
I just went through this. First, check the main relay (for the ECU). OB can point you to where it resides (mine was inside the rear fender - 1992).
The ECU controls the fuel pump relay. If the ECU relay is not switching on, the FP will not be turned on by the ECU.
You can also check the FP by disconnecting the pump from the harness, and jumping it directly from the battery.
Apparently, I haven't learned from experiences with all my other 1990's toys: always carry a spare main ECU relay and a spare FP relay. Locate where they are, write a note, and shove it in the glove box.
Hi Rowland
The Fuel Pump Relay and The Main Relay are in the Boot/Trunk in a Black Box by the gas strut hinge of the Wing/Fender
The Relay in the Red Holder with the Red Stripe is the Main Relay and the Relay in the Black Holder is the Fuel Pump Relay and they both need to be working for the Fuel Pump to work
These Relays are Not interchangeable, as the one with the Stripe has a Diode
As has been said, you could also try putting 12v directly onto the Pump to see if the Pump works on its own
Main Relay is in the Red Holder and the Fuel Pump Relay is in the Black Holder (Not interchangeable) as the Relay with the Red Stripe has a Diode
Pins 85 and 86 are the pins that switch the relay off and on. One is powered by the main relay, the other by the ECU.
Then are Pin 30 provides the battery power. It's a dual output relay, so one of the pins 87 are the output power to the fuel pump. The other is used to provide heating power to the 02 sensors.
To check and see if the relay works, remove it. Place +/- 12v across pins 85 ad 86. Check for continuity between pin 30 and both of the pins 87.
Received 10,980 Likes
The fuel pump relay is triggered by the main relay so, if the fuel pump relay is operating correctly, the main relay is OK
But, to answer your question, yes, it is checked the same way. Apply 12v "+" to pin 86 and apply ground/"-" voltage to pin 85. The result should be continuity between 30 and 87
Very roughly speaking I'd say that 1981-1986 HEs were pretty standard across the board but changes started coming along in 1987-88 with the addition of 'idle enhancement' relays and such
