V12 grille badge
I've noted those early XJS "S-Type" ads out there. As an Ad person I can't say they're very well designed, but more to my point they clearly referred to the XJS as the "S-type" at the time. Later the "S-type" appeared and somewhere in between they dropped the "S-type" label for the XJS.
Istanbul not Constantinople.
It's not the S type of the XJ... The S type is always a saloon/sedan, hence the name plate for the last S type. The S means SPORT. So XJ-Sport. In Relation to the XJ-Coupé for the short lived 2 door coupé from the early 70ies.
It could also mean Special but I can't find the source anymore...
Iirc only the 3.6l got the S badge. S for slow Haha... Sorry for the pun!
IIRC your engine was replaced. The grill needs to be removed to do that.
I suppose the grille would stay on the bonnet assembly, which then is removed when doing major jobs like this ?
Anyway: If the S-badge is wrong for a V12, then I need to change it, no matter why it has been mounted...
The engine was changed twice: From original preHE to another preHE in 1989 and finally to the current 1989 HE engine in 1996.
leo_denmark (03-20-2017)
The following 3 users liked this post by JigJag:
Received 10,955 Likes
I think you're right regarding the USA market. Oddly, "S-Type" and "XJ-S" were both used in the very same advertising. The "S-Type" identification extended even into the early 80s, at least.....
http://www.jag-lovers.org/brochures/...0/77xjsa_l.jpg
http://www.jag-lovers.org/brochures/...m-2-77_2_l.jpg
Jag-lovers brochures - a 1981 XJ-S Brochure Page
Jag-lovers brochures - a 1978 XJ-S Brochure Page
No mention of "S-Type" in this UK brochure:
Jag-lovers brochures - a 1977 XJ-S Brochure Page
The following 2 users liked this post by Doug:
Daim (03-22-2017),
leo_denmark (03-22-2017)
My '96 had the black plastic grille which I have now replaced with an old chrome one, and I specifically got an S badge for it, the V12 wouldn't do for a 6 cyl.
Best I can discern, the S badge was used on the 89-91 6 cyl models, then the grill was changed to the black plastic one with no badge on it.
