V12 injector loom DIY build with pictures !!!
a quick update
i have just discovered that the 4 pin connectors i have used to join my looms to the main harness will also fit the marelli style coil packs
i was reading other threads on the matter and as i had some spare marelli coils turn up the other day i thought i could try it out,
and its a perfect fit , you have to use the ' male ' section of the plug , the shorter one with the yellow rubber seal on the outside that fits inside the other plug
this is only for the marelli system , as this will not fit Lucas coil packs
so i can now replace my broken plugs on the coil supplies , as the ' holder loop ' has broken off ,
BB
BB
The Marelli ignition modules are Bosch 0227 units
Bosch 0 227 100 124 Ignition Control with MegaSquirt-II
Received 9,007 Likes
I got the wire from here
10M Red Black 16 AWG Soft Silicon Wire 600V 200°c 3135 | eBay
I bought multiples so I had enough to complete the project with a little spare left over
BB
BB
I have my ends, just need the wire,
I even have a weather pack crimper for the 4 wire ends...
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/426x320/img_0712_d7ddc2339ccf8338b6d89c0c6c46ab3300bb1a11.jpg)
got these for fuel injection... they are a lot more positive locking that the ones they are replacing...
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
#30
as at lunch I went out to the jaguar and unplugged the connector on the Coil and plugged in the new weather pack....
sadly as I unplugged the connector the plastic that sticks up in one part broke off and I had to go get a long needle nose and fish out the broken piece of plastic before I could plug the weather pack in or the connector that I needed to drive the car with...
ah... the parts are just OLD... new coils go onto the list...
the wiring to the coils are bear in a spot or two... time to replace with new coils new wire and new weather pack connectors....
Still I Have a boat load of them..
#33
Almost. For those finding this in the archives, the Jaguar harness has to be modified for BIM124 to work:
https://www.jaguarforums.com/forum/x...0/#post2202846
Wolfy
05-28-2024 08:06 AM
andyw
09-26-2015 01:59 PM
