V12 injector loom DIY build with pictures !!!
Old 12-03-2014, 02:33 PM
Brake buster's Avatar
a quick update
i have just discovered that the 4 pin connectors i have used to join my looms to the main harness will also fit the marelli style coil packs
i was reading other threads on the matter and as i had some spare marelli coils turn up the other day i thought i could try it out,
and its a perfect fit , you have to use the ' male ' section of the plug , the shorter one with the yellow rubber seal on the outside that fits inside the other plug
this is only for the marelli system , as this will not fit Lucas coil packs
so i can now replace my broken plugs on the coil supplies , as the ' holder loop ' has broken off ,
BB
Old 12-05-2014, 11:35 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
The Marelli ignition modules are Bosch 0227 units
Bosch 0 227 100 124 Ignition Control with MegaSquirt-II
Old 04-11-2015, 01:06 PM
Received 9,007 Likes on 4,113 Posts
Superb, great job and thanks for posting
Old 04-21-2015, 01:17 PM
Jonathan-W's Avatar
Originally Posted by Brake buster
I got the wire from here
10M Red Black 16 AWG Soft Silicon Wire 600V 200°c 3135 | eBay
I bought multiples so I had enough to complete the project with a little spare left over
BB
thanks Brake Buster,
I have my ends, just need the wire,
I even have a weather pack crimper for the 4 wire ends...
Old 04-21-2015, 02:10 PM
cool
i would buy more wire than i suggested initially , better to be looking at it than looking for it.........
good luck with the project,
do you have the markers ?
i can post out a full set to you from the UK for very little money
BB
Old 04-21-2015, 03:12 PM
Jonathan-W's Avatar
got these for fuel injection... they are a lot more positive locking that the ones they are replacing...
cool
BB
no I did not get any markers
cool
BB
That would be great! PM you an Address, payment options?
Old 04-21-2015, 03:48 PM
they look ok ,
pm sent
BB
  #28
Old 04-22-2015, 10:15 AM
Jonathan-W's Avatar
Weather pack 4 pin male - female
any one need 4 pin weather pack connectors...?
I have more than a few extra...
Old 04-22-2015, 01:54 PM
something to remember, one side of those 4 pin connectors also fit the genuine Marelli coil packs
BB
  #30
Old 04-22-2015, 05:53 PM
Jonathan-W's Avatar
BB
this is TRUE
as at lunch I went out to the jaguar and unplugged the connector on the Coil and plugged in the new weather pack....
sadly as I unplugged the connector the plastic that sticks up in one part broke off and I had to go get a long needle nose and fish out the broken piece of plastic before I could plug the weather pack in or the connector that I needed to drive the car with...
ah... the parts are just OLD... new coils go onto the list...
the wiring to the coils are bear in a spot or two... time to replace with new coils new wire and new weather pack connectors....
Still I Have a boat load of them..
  #31
Old 10-17-2016, 06:28 AM
Pudelspringer's Avatar
Hi BB,
Did you ever decide to make any spares?
  #32
Old 10-17-2016, 12:37 PM
luds1's Avatar
HI B B Great work love the pictures and description
well done
  #33
Old 03-11-2020, 07:16 PM
FerrariGuy's Avatar
Almost. For those finding this in the archives, the Jaguar harness has to be modified for BIM124 to work:
https://www.jaguarforums.com/forum/x...0/#post2202846
Wolfy
05-28-2024 08:06 AM
andyw
09-26-2015 01:59 PM
Bcrary3
09-11-2015 10:36 AM
pocketrocket
09-03-2015 07:44 PM
Quick Reply: V12 injector loom DIY build with pictures !!!
