V12 Quick Question
Received 10,916 Likes
Check the attachment for info on "Digitial Ignition", AKA "Marelli Ignition"
In a nutshell the system functions as two systems in one. Two coils, two control modules. And a dual plane ignition rotor within a single distributor. Timing functions controlled by an ignition ECU inside the cabin.
If the plugs are too worn or improperly gapped, or the plug wires develop excessive resistance, the rotor will burn thru...typically in such as way that the engine runs on a single bank of cylinders while the other is nearly dead. The failing bank dumps fuel into the cat converter which over heats and can actually cause a fire. XJSs have burned down this way.
Keeping the system in good order and regular inspection of the rotor can prevent this. Be aware of any loss of power and stop driving if it occurs
Others will chime in with more detail but that's the gist.
The following 4 users liked this post by Doug:
