V12 revs 'hunting' at low rpm when pulling away
So, I did commentt on this issue several months back on my newly acquired 88 V12, 5spd 150k km. The car had not been driven much in the month or two before I bought it. For the first few trips it ran fine.
Then out of the blue..........pulling away from standstill you applied the gas and the revs cycled up and down even though my foot was stationary on the gas pedal. Needed to increase revs to 3000rpm and do a 'racing start' to be able to pull away from standstill.
At the same time on the highway if you backed off the gas and then ever so gently reapplied gas (in same gear) the transmission would 'slam' with a big jolt...... quite unerving!
Was like this for maybe a couple of short trips and then cleared itself.
Flash forward 7 months and the car has been sitting inside at my mechanics garage getting various items of work done as and when he had time to do it (car off the road for the winter, so no rush). Cam cover gaskets have been replaced (leaking), new heater core etc.
He called me today to say that the symptoms above have returned, along with a 'clacking noise' which seems to move around. It is also running ever so slightly 'rough' at idle (was fine before). He diagnosed a dodgy injector on the right bank, so first step will be to put in a known good injector to see if that cures it. FYI my mechanic is super knowledgeable about Jags and the V12 and has been awesome to work with. Just thought I would post on here too, as more minds the merrier!
Wondering if the above symptoms strike a chord with anyone? I am in Toronto, Canada and it seems no local shops that will rebuild injectors. I see that rebuilt injectors are available in US for ~$200........ is that the only recours for a replacement injector?
Any and all thoughts appreciated!
Quentin
Quentin
Quentin
Quentin
Can’t say if the manual transmission changes the normal explanation but…. Hunting is usually a vacuum leak, misadjusted throttle rods (plates), and broken throttle shaft bushings. The throttle shaft bushing will suddenly crumble. The throttle rods will often unwind or wind themselves up unless there’s a dab of lock tight but thats usually a gradual process. Vac leaks are pretty sudden too… rubber gets hard, falls off. Id’ start with these basics before doing anything expensive like checking injectors.
it seems one injector is playing up based on stethoscope diagnosis. I wonder if a sticky injector can be intermitent? Will pass on your thoughts. Much appreciated.
Quentin
The following 2 users liked this post by Greg in France:
Grant Francis (05-09-2023),
orangeblossom (05-09-2023)
Thanks for your thoughts. A short in the loom could also explain why it appears to be intermittant? My mechanic did tidy up the loom routing while he was in there so that could be why the issue has reappeared. Replacing the injector loom was PM I was pondering. I read up on it re. Making one yourself or buying one off the shelf. Off the shelf would be quicker. Will do some more research re. Potential suppliers. Is there any source you would recommend?
Quentin
Received 10,872 Likes
I'm wondering if the ECU was recalibrated as part of the manual transmission conversion?
The system is designed with a closed throttle fuel cut-off; the injectors stop injecting. When the throttle is subsequently opened, the injectors are commanded back into operation. Depending on load, RPM, and road speed this could cause quite a jolt.
The inherent slippage of an automatic transmission torque converter absorbs this. But, with a manual transmission, there's no slippage or cushioning effect.
Just a thought.
The following 2 users liked this post by Doug:
Greg in France (05-09-2023),
Just a thought.
The 5spd conversion was done in 2015 and it had been running fine. Agreed, the jolt was like a big dumping of gas into the engine. How does one go about recalibration an ECU I wonder?
Plan at present is to check for vacuum leaks and then replace the 'bad' injector.
Greg,
Quentin
Quentin
