V12 Timing Chain Guide Wear
After waiting over a month for an engine stand to be delivered, my V12 teardown/rebuild continues..
Upon removal of the timing chain I've encountered much more wear on the guides and tensioner than I would have expected from an engine with 63,000 miles. There's also a strange wear pattern between the upper tensioner and its stop. Everything else so far has been in mint condition. Thoughts?
Seen that a bot over the years.
Snaps are a tad too close for my one remaining eye to be 100%, so my own findings is all I will state.
Lousy oil change periods.
Cheap and nasty oil used.
Too much cold stop start running, shops and back, etc.
The actaul plastic tensioner is not doing its thing, as in not released properly once the timing cover is refitted..
OR
It has been run with a broken tensioner, which was replaced??, and the wear on the guides ignored, hmmm.
One I did years ago with a snapped tensioner, he wound the engine backwards, had 340K kms, he was the 2nd owner, and no real signs of that sort of wear on anything. OK, a PreHE, but same animal.
OR
Greg in France (11-27-2022),
orangeblossom (11-29-2022)
The following 3 users liked this post by EcbJag:
The following 4 users liked this post by Grant Francis:
BenKenobi (12-02-2022),
EcbJag (11-29-2022),
Greg in France (11-29-2022),
EcbJag (12-06-2022),
Greg in France (12-06-2022)
Sleazy
04-18-2022 05:06 PM
dan02xk8
03-30-2019 10:41 AM
