V12 Timing Chain rattle
We were slightly off mission today and got distracted by a "cheap" XJS that was advertised locally.
The owner said it ran but made a "ticking" noise....
Neither myself nor smgdata had heard this particular sound from a V12 before......
Unfortunately on closer inspection it appeared to have a broken timing chain tensioner. We could wiggle the timing chain about an inch with a screw driver through the oil filler cap.
Just wanted to get feedback if our diagnosis was correct ?
orangeblossom (08-14-2017),
smgdata (08-15-2017)
Rumor? No... Real life. All AJ26 and AJ27 until August 2001 will die if not treated Done it about 19 times since last year!
Anyhow... I'll then drive like an old Volvo red block owner. Until the chain/belt snaps... And then simply fit a new one
The valve noise you are remembering is when the HE drops a valve seat from massive overheating. Generally mashes itself into a pulp, then the head of the valve parts company with the stem, and the piston becomes a very LO comp version.
The preHE did not have that problem that I have ever come across.
Drive it like ya stole it, the only way to keep a V12 running proper.
Sarc (08-16-2017)
The last drive I did in mine before taking it apart was to go to a tunnel and just toe it! 1st gear and wellies! Oooooh did that sound nice! There aren't many tunnels here, so I went to my nearest one late at night... Mmmmhm delicious!
The following 2 users liked this post by Daim:
Grant Francis (08-15-2017),
orangeblossom (08-15-2017)
