V12 transmission cooler lines?
There are these two hard metal lines that connect to the radiator. One hits the top beneath the upper radiator hose and one connects down low. I cannot seem to get it off because none of my box ends fit and neither does my adjustable crescent wrench. Any advice on how to get the lines off? I'm replacing the water pump and radiator.
The transmission line fittings on the radiator is off-set because they are mounted on a tapered side of the radiator rather than straight ahead like factory. I will try to bend the line ever so slightly forward and see if I can reach it.
The top should be ok but the bottom line is worrying me.
Photo is me looking down at the bottom tranny line mounting point and you can see the end of the line itself and the gap between them.
al_roethlisberger
06-13-2018 12:45 PM
atilamejias
21
03-01-2008 07:11 PM
