V12: From U.S. to European Compression Rate?
How did Jaguar offer two different compression rates for the same pre H.E. V12 engine? I assume the block, crankshaft and flat heads are identical since those parts are expensive to modify. So what is different, the rods or the pistons?
How hard would it be to change a 1976 pre H.E. V12 engine with U.S. emissions components and U.S. compression rate to the European compression rate? (BTW: I just realized that I should have bought the 1976 RHD XJ-S that I resisted.)
The pistons were different between the 8:1 and 10:1 engines. To change compression, all you would have to do is change the pistons.
That being said, the pre HE and early HE blocks are the same, so you probably could update to the HE pistons and heads. I've never done that, so check with V12 experts. You can probably buy a running HE and drop it in cheaper than buying pistons and rebuilding the engine.
Grant Francis (11-26-2017)
ronbros (11-27-2017)
Received 10,872 Likes
Greg in France (11-26-2017)
Greg
Man is still learning
Maybe I have problem. I have XJS 1988, Hess&Eisenhardt, Lucas, V12, US spec car. The original engine was completely cooked and blue. The previous owner drove without water until the engine stopped. So I bought European XJS, I took the bare engine (block) and put on it the US spec accessories from the old engine.
Now I have: European (UK) engine but with US accessories (sensors, emission system, catalysts, ECU).
When I read this discussion, I feel I have a little problem. Or do not I have?
Thanks,
My feeling is that yes.
Only two shortcomings. But maybe it's not.
First. When idling (cca 750 RPM) the right (A) bank have on the exhaust other running than B bank. Make "plop, plop,.." and it seems, that occasionally some injectors will not open. And I also feel this stumbling on my "***". (Sorry, I donīt know correct word in English, maybe "backround"?) But they are cleaned individually (not on the rail) and if I connect the tester, then it is heard that they are opening properly. At over 1200 RPM, everything is fine.
Second. My real fuel consumption js higher, than computer consumption. But I donīt know, how is computer precise. And I make short trip (cca 150 - 200 km) and 20% is in village or in town. My computer say me 16 l/100 km and true consumption is about 18 l /100 km.
Received 1,236 Likes
As Doug said earlier, there were a very few late PRE HE models (from the bodywork point of view)which had a 10:1 CR and a non-HE but somehow different or revised pre-HE fuel injection and ignition system. These were reputed to be the fastest of all factory V12s. No v12 production cars with the May head were made with a lower CR than the 11:1 AFAIK. Certainly not marketed.
Greg
Greg
hey Greg, does anyone (by a miracle) have a picture of the 1980 10-1 comp. piston, also maybe a pic of the 9-1 Euro pistons ,for comparison!
seems when bought new set of V12 pistons&rings from Welsh 25yrs ago, they said they were Euro hi-compression Pre-HE , thats all they said!
when i put them side by side with my old 7.8-1 ,the bowl was shallower, so i figured thats good,ilike compression!
but makes me think which euro pistons did i get? 9's or 10's. neither ones had any valve reliefs.
