V12 Worn Throttle Linkage (and ECU adjust)
Received 10,920 Likes
What are we gonna do about worn throttle linkages? Of course there's the commonly replaced linkage bushing (C34388) but, if my car is a representative example, there is wear throughout the linkage system. To take out the slop the rods are adjusted to, in essence, pre-load the mechanism...which only adds additional wear.
Specifically, see item #5 here:
https://www.jaguarclassicparts.com/u...kage-5-3-litre
On my car the holes are worn on this ^^^^ piece....although there IS a bushing available for the main shaft, surprisingly
Has anyone drilled out all the holes and installed nylon (or whatever) bushings?
Thoughts? Experiences?
There's also wear where the throttle blade shaft goes thru the throttle body as well. Rebushing the shaft is common with old carburetors so I suspect it would be a routine job for a good carb shop.
As for adjusting mixture at the ECU......
A while back I installed a Super-enhanced ECU from AJ6 Engineering. It dawned on me that I never tweaked the mixture adjustment. Doing so was worthwhile...even though I was already happy with the way the engine behaved. I could plainly hear and feel the engine 'sweeten up' as I turned the adjuster. I ended up 3 clicks rich from the initial setting.
It may sound silly but it was a very 'satisfying' thing
After all these years it still brings a little smile to my face.
The following 3 users liked this post by Doug:
67ECoupe (07-30-2019)
Linkages were ok, it was the plate and ends of the rods that were badly worn because the bush was missing so the rod was turning in the plate. I had 2 spare rods off my 6.0L to replace the worn ones.There is no reason you couldn't make new rods cut a thread on one end, I can't remember if the thread is LH or RH.
al_roethlisberger
04-19-2017 08:02 AM
Roger Mabry
11-25-2016 10:20 PM
frombenz2jag
12-12-2013 10:58 AM
Jagxjs
12-12-2012 10:21 PM
