Can someone help me identify what these random Vac lines are? One goes to the distributor but seems to be missing a second half at this cracked orange thing.
And I can't seem to find what this contraption is with a dozen lines going to/from in the space ahead of the driverside tire.
^^^ this illustration is a bit generic. there were a few variations on the canister plumbing over the years
Thnx I had forgotten about the site with it's diagrams - has anyone removed this thing on their car? It seems pointless and clogs my engine bay with vac lines...I need that space for my electric AC compressor.
So from a glance at the engine this entire rats nest of lines and canister is hooked into the crank case vent and crossover pipe T section, your saying that can just be disconnected and the entire mess thrown away? In the diagram it says a line runs back to the fuel tank did you pull that out or is your car different?
Yes, that is exactly what Grant means. I have done the same on a Mates's US spec car. Chuck the lot, and the air pump and its horrible pipes in the V if you have them, replacing it with a UK/RoW spec idler pulley
It does. It runs under the car to just in front of the RHS wheel chassis member where it joins a thin metal pipe emerging from the chassis/boot area. Remove the under car pipe and disconnect it here where it joins the thin metal pipe, leaving the metal pipe as is, and you are done. This is how all UK spec cars vent their tank.
As Greg said, but, I left the pipe under the LH side of the car, and simply put a rubber plug on the exposed end of the open pipe in the LH wheel arch area.
Then, when the tank was out, as you do with these cars, I plugged all the none essential pipes and rubbish in the boot, and still left the under car pipe in situ, getting lazy.
So far in the past week I removed the smog rails - much easier by cutting the little pipes with metal snips no need to remove any hoses or linkage and sealed nicely with grub screws/hi temp gasket, took the 15-minute fuel timer and smashed it in a fit of rage, replaced coolant filter and tagged with coloured tape all the vac lines I can delete with this carbon canister crap. Just waiting for Saturday to finish it.
If anyone is interested the following image is my 3rd coolant filter in roughly 6000km installed after a few proper chemical rad flushes and Shop-Vac assisted flushes. Still pulling sludge out its unbelievable.
It is generally the remnants of the head gaskets as it dissolves in teh coolant/water.
NO HARM, it is an open deck engine, so NORMAL procedure.
When you pull the engine down, at about 500K miles, then the block sludge can be scoped out. Mine had nearly 2kg of that crud, and the less weight now means it goes FASTER, whoopee.
As for the emission junk, I simple let it idle, ripped stuff off, CAREFULLY, until it died, then repluged the last thing, restarted it, and moved around some more, man, I had some serious piles of rubbish, and this was all before computers and Forums, so seat of pants stuff, luv it.
