Vaccum system overhaul
Old 06-12-2013 | 04:44 PM
Pif's Avatar
Pif
Default Vaccum system overhaul
How much line, and of what size, would I need to redo the entire vacuum system on a 1985 XJS?
Old 06-13-2013 | 10:01 AM
Greg in France's Avatar
Assuming you are referring to the ignition vac lines, this is what I did:
  1. remove all of it, pipes, little solenoids etc etc and block off any unused ports to the manifold.
  2. renew the vac capsule
  3. run a single vac line from the underneath of the A bank throttle body (where there is an outlet correctly sized) to the vac capsule
  4. disconnect the loom from the water temp switch on the A bank rear water manifold and insulate the ends and tie them off somewhere;
This will deactivate the 15 minute strat-up timer which just uses extra fuel to no purpose, and you will notice no adverse change in the cars performance. I was advised to do this by the Jaguar Enthusiasts Club guru, the great David Marks, and my car has been like this for years. Highly recommended
greg
2001 White XJ8
02-25-2021 06:02 PM
Roger95
09-25-2015 03:05 PM
sogood
09-15-2015 08:35 AM
scatcat
09-15-2015 07:55 AM
avern1
09-08-2015 07:25 PM
Quick Reply: Vaccum system overhaul
