Vacuum fuel rail temp sensor
Hi all.
Can someone explain how the vacuum fuel rail sensor works. I have just had a look at mine with a cold engine I can suck on the pipe from the inlet manifold to the sensor and can’t get a vacuum. This might be correct and as the fuel rail heats up the sensor closes to allow vacuum to the fuel pressure regulator. I ask because mine is a little difficult to start when hot and runs a little rough but only for a few minutes. Cold stating is perfect with cold tick over about 900rpm dropping to 650 when warmed up.
cheers Rob.
cheers Rob.
My understanding.
Cold engine.
Vac passes to the FPR as normal, and that allows vac regulation of the fuel pressure. 35ish PSI.
HOT engine, as in a heat soak shutdown.
That sensor closes the vac supply, SO, the FPR defaults to the NO VAC setting, 41psi I think, and that is meant to allow easier HOT starting.
None of mine worked. I removed them, plumbed the vac hose Inlet spigot to the FPR.
HOT starts are fine.
Biggest HOT start issue is grubby contacts at the EFI Resistor Pack plug/socket, RHF corner of the engine bay. Cleaning them WELL, has ceased HOT start issues on 8 down here that I am involved with.
Our summers are HOT by most places, and engine bays get HOT. Fuel boils in the rail. Injectors cannot inject vapor, only liquid.
Also, a couple ON-OFF-ON of the ignition switch very quickly flushes the hot fuel back to the tank.
Cold engine.
The following 6 users liked this post by Grant Francis:
David84XJ6 (08-21-2021),
Doug (08-21-2021),
Greg in France (08-21-2021),
orangeblossom (08-21-2021),
roman_mg (08-22-2021),
and 1 others liked this post.
Grant Francis (08-21-2021)
Andreas Schmieg
11-28-2016 02:34 AM
