Vacuum line question
There is a line going to the fpr, the port i was looking at was below the port supplying the fpr. I just put a rubber cap on it so it wasnt a leak.
I haven't tried plugging the hose going to the aav, but I will do that tomorrow just to see what happens.
I know the spec is .002, but when I set it to .002 the car wont start. I spent a little time this afternoon opening up both sides in tiny increments until I found a setting that the car would start and that ended up being .004. I read somewhere that the earlier cars were set to .004, dont remember where i saw that, but it was interesting that is where I ended up.
Im not sure where they were set when it was idling at 1500. When it was idling that high I didn't measure what it was set at, just stuck the .002 gauge in there and saw that it wasnt right and reset it to .002. Then later opened a little at a time until the car would start. I think for the moment the original high idle problem is solved, now its just a matter of tinkering with things until everything is where it should be.
jagstuart
05-18-2017 07:46 PM
