Vacuum pipes
Vacuum pipes
Evening all. I have a question on the vacuum pipes that go to the end of the inlet manifold on the drivers side. There is a little cluster of 3or4 pipes and a blank. Does it matter which pipe goes to which or are they all supplied the same bar the one that is blanked. I know one is the trans vac pipe not sure on the others. Much obliged.
orangeblossom (11-27-2018)
OB, that is by the way not an EGR valve. EGR stands for Exhaust Gas Recirculation. A vacume is no recirculation. That is simply a vacume switch. And even that isn"t fitted to all XJ-S models. My 89 had a working CC and direct draw off the intake manifold. No little vacume switch at all in that area.
Received 10,920 Likes
new mexico
04-29-2017 02:28 PM
