Voltage Drop on Braking
Have had my '95 V12 convertible since May, always had a noticeable voltage meter drop when applying brakes. I did the following to find the fault, with no appreciable change:
Where to look next? The brake light switch and wire connector above the brake pedal? My understanding is that there is no brake light relay in these facelift cars.
- Pulled brake/taillight bulbs
- Disconnected bulb fail sensors
- Cleaned battery terminals, cables and main ground point in trunk
- Pulled and cleaned all circuit wire connectors
Here is what you should do... Buy a cell phone charger with a volt meter like the one shown below and monitor the actual voltage. It's good practice on any old car.
There is a relay for the stop lamps and its located on the left hand side of the boot, see below.
The following 2 users liked this post by icsamerica:
Greg in France (08-28-2021),
ralphwg (08-28-2021)
Must be where I haven't looked yet
Thanks for the quick and detailed response.
I pulled the left and right inner trunk panels during my testing. Also installed fresh 7528s pending a decision on LED replacements. In the left rear wheel arch area only found the ABS relay, CD changer and what I assume is the audio amplifier. Maybe I need to look behind/above the spare tire?
Also, I have a Bluetooth adapter with voltage display in my cigar lighter. If I keep my foot on the brake it will show a slight voltage drop, but not one as sudden or large as the dash volt meter.
BTW, I also cleaned the connector that feeds the dash gauges, read somewhere that might help.
