Warning light... What is this?
Sounds like you may have a bad solenoid. To be sure, run diagnostics. I had the light come on in mine, and I had a Jag dealer run diagnostics. Was a solenoid fault. Not a bad job to replace. There are three (IIRC) and not knowing which one, I replaced all three, and the filter at the same time. My L480E has a drain plug. Drained the fluid, removed the pan, replaced the solenoids and filter, reassembled. Light was off.
Greg in France (03-30-2021)
StephanWolf
11-07-2010 08:40 PM
