Water Temp Sensors/Transmitters
On a 1976 V12 pre-HE XJS there are temperature sensors behind the thermotime and CTS switches. I assume the sensor on the right bank behind the thermotime switch, which has a single prong, is the water temperature transmitter and reads ~2200 ohms at ~45 degrees F. The second sensor on the left bank behind the CTS and under the intake manifold, I have no idea what it is for and reads zero ohms. What is this sensor (it has two circular prongs), and what are the normal ohm values for both these two different water temperature sensors? Many thanks!
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
