Water Valve C41051
Try looking around ABS pump for red plastic line, if it's a marelli car probably in the bundle exiting the flexible rubber protector.
The following 2 users liked this post by baxtor:
Daim (07-04-2018),
motorcarman (07-06-2018)
Baxtor thanks for the advice. I wanted to scope out things as you suggested. Apparently, someone purposely disconnected the heater valve. What I found were three vacuum lines coming through the fire wall at the same place. A solid red line just as you said, a black with yellow strip line and black with white strip line. The red line is hooked up to vacuum port on the engine as is the black and yellow one. Someone put a screw in the end of the black and white line plugging it up and left dangling. I don't know what all these lines for but why would someone rerun and plug the vacuum lines. Any idea? Any advice would help. Thanks.
I don't really know. I know nothing about Jag's except that I always loved the XJS and always wanted one. I found this convertible by accident with 32,000 miles on it sitting in someone's barn for the last 25 years. Now if we were talking mustangs, well that's another story... Anyway how can I tell? It's VIN # is SAJNV4849KC164226 if that helps.
One of the other vacuum lines runs into the ignition ECU in the footwell of your car ( passenger side) not sure of which line it will be, the other will be the feed to the vacuum reservoir. It's easy enough to get to the ECU so you could get in and check which line is plugged in at that end.
Total of three vacuum lines, one intake manifold to ECU, one intake manifold to vacuum reservoir and one air con to heater valve.
Received 10,872 Likes
The heater valve closes with vacuum applied and opens with vacuum removed. So, perhaps there was a control problem and the vacuum hose was removed so as to ensure the valve stays open to provide cabin heat? I dunno. Just a guess.
Someone went through a lot of pain to do what they did. I'm going to trace the lines as Baxtor recommended so we can figure out what to do next. I get plenty of heat but maybe that's the problem with the a/c. Fully charged and I only get 60 F out the vents and that's on a good day.
If that's the case you could as a stopgap fix simply connect heater valve to manifold vacuum supply thereby closing it whenever engine is running.
The attached diagram shows how these blend flaps operate.
Of course your problem might be something completely different.
Timothy
05-16-2012 07:14 PM
