Waterproof Car Cover for XJS Coupe
Mine wasn't cheap, it is one made to fit the XJS and I bought it at Cover Craft on line. Its something like 5 or 7 layers but I use it in the winter when I store the car up so the garage is open in case i need to work on one of my other cars during the winter
you can change vehicle, this is were I got mine
https://www.carcoversdirect.com/part...1752/materials
The cheapo $30-60 ones you see at autostores can work. I have had 2-3 fabric ones and one that seemed to have a PVC outer layer.
The PVC one was the most waterproof but the sun ate it up faster. The others are treated with a chemical to be waterproof and generally didn't completely waterproof in a thunderstorm with very heavy rain. The quality seemed to vary, with the chemical wearing down after about 1-2 years.
I can't imagine spending $400 on a cover because the sun is still going to eat it and the chemicals will still wear off (I'm sure they will last longer but still).
Keep in mind covers arent perfect, and you certainly still find wet spots on your car in some conditions where moisture in the air couldn't escape from under your cover. Easily solved with a rag and detailer left in the trunk.
