Weird ignition issue
Weird ignition timing issue
My car has been sitting for 15 years alright. Now, having a second life, I'm slowly addressing all the million issues it has. I'm driving it every day a little. Engine didn't run well. I was planning sending injectors in for check. And replacing the fuel filter is in order. And checking the fuel pressure is planned.
Today something happened. I was light on the gas and revved over 2500, and suddenly it jumped forward like a young Jaguar. Then the coolant temperature dropped. So now I'm guessing it is not fuel issue at all causing poor performance. Ignition was too retarded. I'm wondering why and how the heck it suddenly started working. Now sometimes it jumps forward when revved over 2500 and sometimes it doesn't. Shall I take the distributor apart or there may be some XJ-S specific vacuum issue? I admit I haven't read thru EFI/Ignition manual yet.
Segfault (07-18-2018)
The springs shouldn't need to be replaced. However, the workings are probably gummed up, so taking it apart and a good cleaning will improve things. Make sure that the vacuum advance mechanism actually moves under vacuum, I bought a new one and the rotating mechanism was frozen in place. I ended up cleaning the old one and reusing it with a new vacuum capsule. Once all the moving parts are clean, I lubricated them with synthetic ATF, to withstand the heat.
Originally Posted by Kirby's Book
Unless your distributor has been overhauled, it is seized right now. Period. This has proven to be a 100% failure rate, every time, every car, there simply is no doubt anymore. And a seized advance unit results in low power, overheating and major engine damage if not corrected. If you are not absolutely positive that your distributor has been overhauled already, it is imperative that you schedule an overhaul as soon as possible -- and drive the car very gently or not at all until it’s done.
MLRocafella85
06-18-2011 02:19 PM
WillieE
05-17-2011 11:14 AM
85_305
12-10-2009 07:12 AM
