What is this
Received 1,442 Likes
By the size of those shorn off cable ends, it looks to be from power distribution lines - eg mega fuses?
Why it was put there is even more interesting?
Was it just wrapped, tied, or just lodged there?
Cheers,
Ken
It's a part of the wiring harness from the fuel pump relay to the in tank pump on my 94 XJS. It had about 4 inches of harness to the pump side and a foot to the other connector, No power to the pump so I unplugged the pigtail to check it. No continuity from one end of the pigtail to the other with this in. Some kind of electric gizmo to either reduce amperage to the pump??
Bench tested the pump with out this and my pump runs. The big question is why its there and will I damage the pump without it. I accessed my intake pump 3 times now and don't really want to do it again.
Just a guess, as I know nothing of this model, it could be the gizmo referred to in this thread:
https://www.jaguarforums.com/forum/x...l-pump-247586/
If so, then it is some sort of voltage spike protection. Whether it is needed I have no idea, but Scott made one up, he said, using a different and more reliable method.
The following 4 users liked this post by Greg in France:
Bingo, Greg . . . .
More commonly seen as a reverse biased diode across relay coil to protect the winding from change-of-state spikes.
note that tiny diode parrallel to coil of Fuel Pump Relay #2 below
Known as a radio frequency interference (RFI) filter.
To OldCoastie . . . here is a screenshot of your '94 XJS.
Note how the RFI zener diode is reverse biased (ie anode to ground)
**Edit . . . Eliminate it removes that protection . . . How much is that new fuel pump you may soon need?
PS . . . did you find the second one?
Doug (07-02-2021)
Greg and Cat, thanks for confirming what I suspected. Fortunately, I found one on E-bay that day to replace it. Just another week delay as shipping here is horribly slow these days. My knowledge of buffers/protection devices is limited but I believe Greg when he said it's probably there for a reason. This Jag has certainly been a learning experience for a former 60's to early 70's former MG/Triumph mechanic.
(Cat, my Jag has a 6 cyl and one pump so I'm guessing a second Ziener isn't needed.)
On my 94MY electrical diagram, (I was finally aware enough to look there), the device is called and RFI Protection Module. On Cat's diagram its called an RFI Filter. Aren't RFI "devices" inserted to dampen radio interference? If that's the case, I should be safe without it? I don't listen to the radio with the top down anyway.
Two more pictures. This is the third time Ive replaced the fuel pump. I can now do it in 3 hrs start to finish. Vee i understand what you're saying about interference to relays and such. There are only a couple dozen relays in the trunk along with two ECUs. I can wait until the replacement shows up. In the meantime I have a Zener free jumper if I need it.
In this case, it is the switching of relays or, more commonly these days, high speed digital devices like ECMs either up or downstream, which in their operation can produce very short but high intensity voltage spikes that can take out other electrical or electronic components. The well designed placement of RFI filter/suppressor/module, such as here, not only protects that fuel pump from other switching devices, but vice versa, may be protecting even more expensive components from that fuel pump.
The wiring diagram from which I posted the screenshot in my earlier post was taken from Gus' repertoire at <jagrepair.com> for MY94, so I suggest you investigate further before overlooking second RFI protected pump. Not sayin' it's in, under or anywhere near fuel tank, and you will note it has entirely different wiring colour codes. Is it an electrical high pressure pump fed from low pressure pump at tank, or accessory injector feed or summat?
So, the RFI Filter is like the dangling strap under cars of old . . . anything that sinks away that zap as you alight, has just saved you a motza of cash for modern (read, sensitive) electronic components.
Cheers.
Ken
OldCoastie (07-03-2021)
