What is the Best Way to Clean Facelift Window Switch?
I have a 1996 XJS and the drivers side window switch is starting to fail. I took it apart and there is some black corrosion on the contacts. I am attaching a picture after spraying it down with contact cleaner.
In the past, I used some sandpaper, or some abrasive, to clean off that black corrosion. Big mistake. The switch worked great, but removing a protective layer only accelerated the return of the corrosion. I had to buy a new switch.
Any tips on cleaning this up the right way? Thanks.
