What climate control system 1995
Can someone tell me what kind of climate control system is installed in a 1995 4.0L Conv. Is it the Delenair III system? I have an electronic manual for Delenair from someone or someplace on this forum, but I'm not sure what the car is supposed to have.
Also, does anyone know where the temp sensor is located?. I imagine it is a tiny fan that sucks sample air over a sensor.... but mounted where?.
Received 10,871 Likes
Should be the MK III system....but the Mk III was subject to various revisions so, depending on the problem you're trying to fix, you might need to get the tech info that pertains to your specific year/version.
Early cars had the temp sensor in a tube above the glove box, with the inlet on the underside of the dashboard lip. I'm pretty sure that late cars such as yours had an aspirator, as you describe, in one of the under-dash knee panels
Let's hear what others have to say
jag_guy_2020
08-16-2014 06:17 AM
RCSnyder
01-22-2014 12:30 PM
