Anybody have access to a 1972 color chart? Hopefully with numbers? I understand this is Lacquer, which I really enjoy working with. But rather than do a whole strip and repaint I’d like to match and just Re spray. I’m very fortunate that there is no rust to cut out and the paint itself is in semi decent condition once I buff it out. I’d really rather do a Re spray than be forced to strip all the paint off and do a total repaint.
Regency Red? Not sure it can be anything else. (Certainly not Signal Red)
Thank you. I really appreciate the DuPont color listing. I do agree that it appears to beRegency Red. I’ve buffed a little under the gas cap door. And on the inside of the trunk.
If that's really Regency Red as per attached pic, then it's either incredibly uniformly faded all over or else the photo is not really representing accurately.
I would just contact Jaguar Heritage with your VIN etc and they'll provide the correct colour specification of the car when built.
Paul
the last time paint was put on this car was 1972. You can start to see the undercoat in certain areas. Look at the inside of the trunk and bonnet.
The car was in storage from about 1986 I don’t want to buff it out since I won’t need to strip to bare metal to repaint. Just sanding with 320 and a respray. Then color sand and buff everything together. If it’s less than perfect? So what? So am I.
I doubt it's lacquer paint, as Jaguar was using various enamels (acrylic and others) by the mid 60's. My 1966 S Type was enamel. GM kept using lacquer paint well into the 80's, but Jaguar was always using fairly advanced paint technology for the times.
The one on that post-linked pic doesnt look like the original Heather. That's either a respray or one of the 2 pink" cars that were painted for export motor shows. This is a better representation of the Heather colour:
But, we're all just guessing aren't we?
If the owner cant find a colour code on a label on the car, then a Jaguar Heritage certificate will absolutely confirm the correct colour.
