What did you do to or buy for your XJ-S/XJS today?
Old 12-25-2015, 03:22 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
had my tires deflated, remove air, and refill with Helium, car is now much lighter/faster.
LOL,LOL,LOL,LOL thats 4 tires
Rick25 (01-25-2016)
  #322
Old 12-25-2015, 08:22 PM
Flint Ironstag's Avatar
Originally Posted by superchargedtr6
Went by my friends house that is a retired machinist, and checked out the 3.3l whipple supercharger he is modifying so I can put it in the V of the 6.0 I am building for my XJS. Yesterday I got the confirmation of the custom set of Total Seal rings for this project. Mailed them a piston, and Ed Law has me a set on the way.
Hope there's a thread for this build!
  #323
Old 12-25-2015, 08:24 PM
Originally Posted by baxtor
Bought a mate for my xjrs. Won't be lonely anymore.
Baxter, love the wheels on the XK8. Are they 19s? Wonder how they'd look on the XJS - probably too big.
HypnoGuru (12-26-2015)
  #324
Old 12-25-2015, 08:41 PM
baxtor's Avatar
Received 1,156 Likes on 746 Posts
20 inch BBS detroits
  #325
Old 12-27-2015, 04:23 PM
FastCat85's Avatar
Default Discovered a new problem and fixed it
To my surprise, the hoses that connect the manifold vacuum balance pipe were collapsing almost completely when the motor was revved up. Went to NAPA and purchased some heavy duty 1 inch hose and replaced the bad hose. I am always surprised at the problems I find.
  #326
Old 12-28-2015, 10:54 AM
Jonathan-W's Avatar
Revved up then closing the throttle?
Yeah, I would replace them... they are not just for balance anymore they are also your startup high idle... and Idle...
  #327
Old 12-29-2015, 09:01 PM
Forcedair1's Avatar
Originally Posted by Daim
Thread revival started:
What did I do to my XJ-S? Well, nearly 1.5 years ago I took a picture (see signature) of my Iron Lady. A few months ago I sent it in to the SNG Barratt Photo Contest. Result:
Overall winner and winner of Modern Jaguars...
Am I chuffed? Yes. Very!
Well done and congrats!
Is your signature a cropped version?
If so, could you post the full original? (Although you may have already done that and I'm not aware).
Thank you and cheers,
Paul_59 (12-31-2015)
  #328
Old 12-30-2015, 11:47 PM
dsetter's Avatar
Originally Posted by dsetter
I share an xjs with my son. He called and said there was some coolant on the ground, and it steamed when he started it but could not see where it was coming from.
Rather than risk him driving home, I drove the 2 &1/2 hours to visit with a set of tools. Once there, found the rear heater hose had a pin hole and was spraying out onto the exhaust. This was in San Luis Obisbo, home of parts supplier xks unlimited, but they were not open this time on Saturday. Managed to remove and replace with a length of straight hose, and have ordered a full set of hoses that the said son can collect from xks and we can replace all over the holidays. Might need extra holidays to do all. .
Once I finished with the replacement, and filled it, and tested it, it stopped raining. That was my sign that it was ok.
Well now removed and replaced the about 20 bits of rubber hose copper washers and 2 thermostats that make up the cooling system. Refilled and ran to temp & pressure and no apparent leaks.
Did change most of the clamps to constant tension bands, where i could. Left the main radiator hose clamps as spring loaded Norma.
Will go through a few more cycles before I declare success.
  #329
Old 01-18-2016, 07:32 PM
Jaglover02's Avatar
Just installed new headlight assemblies on my 1994 xjs convertible. I bought a new left side light from Welsh, and found a right light on Ebay that was advertised as "near perfect" and it was so fine that no one can tell which is the new one versus the salvaged one! And the best part is the seller priced it reasonably about the same as Welsh charged for the left light.
Jonathan-W (01-19-2016)
  #330
Old 01-25-2016, 11:23 AM
Rick25's Avatar
Default fuel sender
Picked up new fuel sender unit. i don't understand why the Jag Factory repair Manual says you have to remove the fuel tank to install a new sender unit, when it is clearly visible and accessible on the top of the tank? Of course, disconnecting and even removing the battery is my first chore.
Jonathan-W (01-26-2016)
  #331
Old 01-25-2016, 12:06 PM
44lawrence's Avatar
You don't have to remove the tank. Just remove as much gas as possible, so the gas level is below the sender. remove the spare tire. Remove the sender.
Lawrence
The following 2 users liked this post by 44lawrence:
Jonathan-W (01-26-2016), Rick25 (01-26-2016)
  #332
Old 02-06-2016, 10:58 PM
cmxjs's Avatar
I've owned my 95 XJS for 2 years now, it's my daily driver in the summer but gets put away for the winter. It seemed to be running a little warm last fall (just over the middle on the temp gauge).
My guess was the radiator was possibly junked up with aluminum salts -- and the plan was to remove the radiator and take it to get re-cored or rodded out. Seemed like a nice weekend project as it warmed up a bit outside today.
No problem getting the bonnet and the radiator top cover removed.
Here is what i found -- 22 years of dustballs matted about 1/2" thick. Blew it all out, and put everything back together -- let's see if that's all it needed -- i won't find out until april when they stop salting the roads!
Radiator junk
Cliff
1995 XJS AJ16 Convertible Brooklands Green/Cream
Massachusetts USA
  #333
Old 02-08-2016, 04:57 PM
ronbros's Avatar
just found two headlight surrounds,left and right chrome.
been a few months finding NEW pair! for 78 XJS.
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-dscn8681.jpg   What did you do to or buy for your XJ-S/XJS today?-dscn8692.jpg
  #334
Old 02-08-2016, 10:08 PM
Carnut66's Avatar
Mine did the same at 50,000.
How did you fix it?
  #335
Old 02-13-2016, 06:08 AM
orangeblossom's Avatar
Received 3,777 Likes on 2,616 Posts
Default Half a Tank of Petrol going nowhere!
With my XJS in Storage for the Winter, not that we had a real Winter this time around, I filled her right up with Petrol/Gas before I put her away.
Then Started her up every couple of Weeks, just to make sure that She would be ready to go back on the road on March 1st.
Having just checked the Fuel gauge, just doing that has so far used a half a Tank of Petrol going nowhere, so this year it might be better to Tax her all year round.
  #336
Old 02-14-2016, 10:15 AM
Jonathan-W's Avatar
what does Petrol/Gas cost you over there? ... it is down to 2.06 a gallon for 93 octane here...
  #337
Old 02-14-2016, 11:13 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
About 8 USD an imperial gallon, but it is sold in litres! Its all tax. Confiscation really!
Greg
  #338
Old 02-14-2016, 05:20 PM
Hi Jonathan
Since She has been off the road for 6 months during her Winter layup, I'm a bit out of touch with current Petrol/Gas prices.
I use Tesco Momentum 99 Octane which I 'Think' is around £6 per Gallon
So an 18 Gallon Fill up would be around £108
Where even just 'Tripping' can easily cost around £40 per day.
Jonathan-W (02-15-2016)
  #339
Old 02-15-2016, 05:46 AM
Beavis's Avatar
Todays purchases...
Alloy Gear shift - C2P9343
New leather gaiter
Number plates and finally - annoyingly, new wheel nuts.
  #340
Old 02-15-2016, 12:49 PM
Jonathan-W's Avatar
Hi Jonathan
I geez I FEEL guilty... dropping 40$ us and going out to warm it up and try and get it to chirp the tires going into second gear...
(Hussein)Obama wants to drop a 10$ a barrel tax on us
orangeblossom (02-15-2016)
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
