What did you do to or buy for your XJ-S/XJS today?
#481
Righty'o then! The front axle has been disasembled. Everything, except for the vertical connections (the attached part with hub, bearing and co). So I am replacing the bushes, the ball joints and most importantly, the rust on the subframe. The worst part is, that there is a hole (see last picture) in an area it technically can never rust... How that? No idea! But I'll be making sure it won't happen again with some drainage holes ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
This whole job was rather easy - apart for getting the fulcrum shafts out. One caused me some minor "pain" (I'll confess, I cursed nearly every single word I know from two languages! And that wasn't enough! So I come up with some new ones... Like Custard... I can explain that one later...
) as it slammed into my forehead and I felt it right through my body... But heck, that is life! ![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Am just waiting for the parts to arrive
![](https://c1.staticflickr.com/9/8629/28776686176_a3ca75c6c0_b.jpg)
![](https://c1.staticflickr.com/9/8896/28776683486_14e7ace48e_b.jpg)
![](https://c1.staticflickr.com/9/8892/28776688076_f7aab1790a_b.jpg)
![](https://c1.staticflickr.com/9/8599/28523967800_813678ed78_b.jpg)
![](https://c1.staticflickr.com/9/8612/28523969340_3948dfe96e_b.jpg)
![](https://c1.staticflickr.com/9/8473/28703111912_e7e7c68628_b.jpg)
![](https://c1.staticflickr.com/9/8566/28703121762_2f079cb35c_b.jpg)
![](https://c1.staticflickr.com/9/8765/28523991400_4a053e6b14_b.jpg)
![](https://c1.staticflickr.com/9/8568/28523993190_bc532131e9_b.jpg)
![](https://c1.staticflickr.com/9/8034/28190882024_00c34c35ce_b.jpg)
Link to the flickr album: https://www.flickr.com/photos/288642...57671215146702
The following 3 users liked this post by Daim:
#482
Daim, I found brake caliper paint (silver in my case) worked well on the wishbones 3 years and its still looks good.
The subframe and spring pans I painted with POR15, this stuff is hard as granite once dry. Get some cheap brushes and throw them away, once its dry you can hit the brush with a hammer and the POR15 will not budge. Its cheaper than cleaning the brush with the POR15 thinners.
Jonathan-W (08-07-2016)
#483
for the manifold
44218 by ABSOLUTE COATINGS (POR15) - High Temp Paint Aerosol Gray
nothing like it staying pristine looking...
#484
#485
POR15'ed today. Applied quite well but the finish isn't perfect. Doesn't matter anyway, as the parts are hidden behind the front wheels and to see the imperfections, you'll need to get on your hands and knees and take the wheels off ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
![](https://c1.staticflickr.com/9/8662/28977613315_cf39e1d747_b.jpg)
![](https://c2.staticflickr.com/8/7549/28361043723_33228f8a97_b.jpg)
![](https://c1.staticflickr.com/9/8862/28361043053_193fb1df4c_b.jpg)
![](https://c1.staticflickr.com/9/8303/28361045033_58f254a367_b.jpg)
I'll treat the rear suspension parts with the same stuff as I am quite convinced, that it should work well
The following 5 users liked this post by Daim:
Greg in France (08-14-2016),
Jonathan-W (08-15-2016),
orangeblossom (08-14-2016),
Paul_59 (08-15-2016),
warrjon (08-18-2016)
#486
I would like to buy it a playmate but unfortunately funds won't stretch anywhere near enough.
1989 Jaguar Lister XJS Convertible (V12) | eBay
#487
#488
#489
I've had an electric polisher in the garage for the last 3 years, still unopened.
Bought it for a previous XJS that turned out to be mechanically a very long way from washing never mind polishing.
She who must be obeyed is away for 36 hours so I decided to focus on my cars instead of hers for a change.
Broke it out of the box, removed detritus and dead things (one of which I am sure that I saw in an episode of Stargate), RTFM'd it, plugged it in and off we went.
Quite pleased with the result and the lack of aching fingers and sore back.
The following 3 users liked this post by Steve M:
#490
#491
Busy day... Replaced both sump and sandwich gasket. New oil filter. New gasket for the bypass oil cooler blanking plate... Finally the light at the end of the tunnel can be seen! ![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
![](https://c1.staticflickr.com/9/8008/29036476721_5da9f84b02_b.jpg)
![](https://c1.staticflickr.com/9/8088/29036466071_193d128fa8_b.jpg)
![](https://c1.staticflickr.com/9/8555/29036463441_0fb8e2bfd1_b.jpg)
![](https://c1.staticflickr.com/9/8613/29036458791_7da27503d5_b.jpg)
![](https://c1.staticflickr.com/9/8260/29036457521_ec0a276e10_b.jpg)
![](https://c1.staticflickr.com/9/8465/29008618332_ed2a2a1118_b.jpg)
![](https://c1.staticflickr.com/9/8594/29114047795_c9aea88072_b.jpg)
![](https://c1.staticflickr.com/9/8291/29114045585_01b18f74ca_b.jpg)
![](https://c1.staticflickr.com/9/8325/29114091175_ecb3809fa8_b.jpg)
More pictures can be found under this link: https://www.flickr.com/photos/288642...57672627577866
The following 4 users liked this post by Daim:
#492
#494
The light is just the on coming Train............
I couldn't find anything in the manual on how to remove the ABS reluctor ring. As its broken it does not matter too much if you break it more getting it off as long as you don't damage the hub.
I'd try heating the ring and tapping it off.
#495
The following 3 users liked this post by BC XJS:
#496
Time to put the engine together again. The oil cooler pipes were redone (cleaned up and painted to look a bit better) and the exhaust headers/manifolds were refitted. The tranny is bolted back on and should now work perfectly (again)
![](https://c1.staticflickr.com/9/8192/29158839652_a9b6da3c0b_b.jpg)
![](https://c1.staticflickr.com/9/8390/28643830324_22dc32f7b9_b.jpg)
![](https://c1.staticflickr.com/9/8331/29232729746_249869f9cb_b.jpg)
![](https://c1.staticflickr.com/9/8040/29267063985_520fe20bc0_b.jpg)
![](https://c1.staticflickr.com/9/8388/29232725826_2055a12d9c_b.jpg)
![](https://c2.staticflickr.com/8/7533/29232719836_ca8c2ce42b_b.jpg)
![](https://c1.staticflickr.com/9/8133/29158842542_3b90ef9835_b.jpg)
![](https://c1.staticflickr.com/9/8797/29232744646_4ac8be43be_b.jpg)
Additional pictures, as normal, under this link: https://www.flickr.com/photos/288642...57671827711590
#498
#499
2 years ago, as I removed the intake manifolds, 12 washers weren't noticed. These fell everywhere. 6 were on the intake, 2 fell into the V, 2 were fished out of the intakes and 2 were missing. I always had a bad feeling that they were in the engine... So I bought a cheap endoscope. Couldn't find anything but my gut feeling was still there. I found 1 washer as I removed the washer. Still leaves 1 missing washer...
Borrowed a pro-endoscope today and found the missing washer... Cylinder 5A had it and I could luckily remove it through the valve clearance... Gut feeling: gone!
![](https://c1.staticflickr.com/9/8771/28698969233_286f083e8e_b.jpg)
![](https://c1.staticflickr.com/9/8317/29032018090_8868151400_b.jpg)
![](https://c1.staticflickr.com/9/8260/29032015740_c8fbf7466c_b.jpg)
![](https://c1.staticflickr.com/9/8873/28698971493_72fbc4590d_b.jpg)
At the same time I checked the bore and hone marks. All top. A few tiny little rust spots, but nothing the piston ring win't remove.
Also reassembled the upper wishbones with new balljoints (XJ40 ones) and new bushes. Coated well in loads of grease to make sure nothing squeaks. One of the two lower wishbones also has some new bushes. Heck, thjs is getting nice again!
Jonathan-W (08-29-2016)
#500
