What did you do to or buy for your XJ-S/XJS today?
Old 09-18-2016, 12:15 PM
JLBolen's Avatar
I guess you could say I purchased this for my 87 XJSC. I had a few spokes leaking air on one of my wheels. So I purchased a manual tire changer, broke it down and cleaned it, then resealed the spokes where they came through the rim. Works great. Cheaper than sending it back to Dayton Wheels and better than a Inner Tube. Also bought a Horn Relay, but still did not fix that.
  #522
Old 09-18-2016, 08:18 PM
JigJag's Avatar
Air pump piping delete today. Not too difficult. Had a bit of trouble getting the air rails out without disconnecting and file lines. I did drop the rear caps off the intakes to move the balance pipe out of the way.
It does clean things up a bit.
Before
After
  #523
Old 09-18-2016, 08:58 PM
Doug's Avatar
Received 10,921 Likes on 7,175 Posts
Good work!
Are those fuel lines original to the car? If so, you might wanna add them to your "to do" list.
  #524
Old 09-19-2016, 05:36 AM
JigJag's Avatar
Sound advice Doug! Braided line is ordered already. And custom fuel rails are in the works as well! Any advice on an actual good technique for extracting these lines from the grip of those tiny steel washer clamps? I understand that is quite difficult.
New snakes for the snake pit are also on the way. Red ones! Taylor 10.4mm, 50 ohms/ft.
And before anyone points it out for me... Yellow fan. I know. Checked again. Still safe. Going with efans and a custom shroud. Still working out the design there. Soon.
Jonathan-W (09-19-2016)
  #525
Old 09-19-2016, 08:10 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
I'm currently taking my new old XJ6 axle apart. It is exactly, apart from a weld, the same as the XJ-S version. Probably due to a change in construction methods.
The PITA are again my favorite parts: the ful-scum shafts... Bloody f**king little pi**ers... We decided to create a new curse here: Custard. A mix of c**t and bast**d. That has been used quite a lot on my old axle...
  #526
Old 09-19-2016, 11:27 AM
NCJagman's Avatar
Default Carpet
Today I installed new carpet in my 92 XJS convertible.
LUXE Extreme Plush Carpet Front Mats for XJS Convertible.
This stuff is plush.
  #527
Old 09-19-2016, 01:40 PM
Purrkitty's Avatar
Today I am continuing troubleshooting an intermittent problem where all the cylinders flood with gas and cause a hydraulic lock sometimes. Once I get more information I'll post my problem. It's not a shorted injector harness; I figured that much. frustrated but hopeful
  #528
Old 09-21-2016, 03:44 PM
orangeblossom's Avatar
Received 3,813 Likes on 2,640 Posts
Got myself a 'Discarnect' Battery Isolation Switch £3-45 on ebay! and fitted it on my 1990 XJS V12
I've also got one on one of my other XJS V12's and wouldn't be without it, as its one of the best pieces of kit that I have ever bought as it eliminates any accidental Battery Drain and as a result my Car always Starts First Time!
And also re-plumbed the Windscreen Washers to get them working again for the MOT.
  #529
Old 09-22-2016, 12:01 AM
BC XJS's Avatar
I used the marine grade battery switch and highly recommend it. No more battery drain. I used marine grade as they are less prone to sparking and I thought that would be best as its beside the fuel tank.
Also I don't need to remove the battery cover to turn it on or off
  #530
Old 09-22-2016, 01:07 AM
leo_denmark's Avatar
I mounted a Climatron A/C amplifier from Jag Prestige in Australia to replace the original C45402
It was a pleasure to hear flaps moving and to get some else than cold air at high fan speed from the vents...
http://www.ebay.com.au/itm/ws/eBayIS...m=331934812351
At the same time I mounted the LH side air channel from the main unit sourced from Just XJS. Nice to be able to fix the cover next to my right foot properly now.
  #531
Old 09-22-2016, 01:27 AM
Greg in France's Avatar
Received 9,342 Likes on 5,478 Posts
http://www.ebay.co.uk/itm/331934812351
Leo, the link does not work, could you post a new link or the exact description, please? I have a mate who wants one.
Greg
  #532
Old 09-22-2016, 02:24 AM
Thanks. Link updated in original post
Contact the seller, there are more than one version. This one fits my 1977 car...
Greg in France (09-23-2016)
  #533
Old 09-25-2016, 08:52 AM
NCJagman's Avatar
Default I bought
Windshield Washer Fluid Reservoir Cap Genuine Jaguar Vanden Plas # DAC4888
It has irritated me for some time that washer filler strap was broken. Today I did a search and Bingo, there it was on eBay. $18.95 including shipping. Well pleased. Now, what's next?
Stephen
Jonathan-W (09-26-2016)
  #534
Old 09-26-2016, 10:08 AM
Jonathan-W's Avatar
Stephen
link please? I find them for 25 and up
  #535
Old 09-26-2016, 10:51 AM
ptjs1's Avatar
Received 3,101 Likes on 2,046 Posts
Jonathan,
The cap, DAC4888 is just £2.75 from Jaguar. Not sure what $ price it is but order via your local Jaguar Dealer and there are no shipping charges. One of their warehouses is in the US so it might be readily available over there.
Paul
The following 2 users liked this post by ptjs1:
Greg in France (09-27-2016), Jonathan-W (09-27-2016)
  #536
Old 09-26-2016, 11:50 AM
Daim's Avatar
Had my new old front subframe and anti roll bar/anti sway bar (depending on country) sand blasted... Looks nice now!
  #537
Old 09-27-2016, 10:11 AM
Jonathan-W's Avatar
Originally Posted by ptjs1
Jonathan,
Paul
looks like another road trip to Mobile Ala. then...
they did my ign keys $10.00 us verses 45 for the lock smiths here...
we make a day of it with the family... Lunch and shopping and all.....
  #538
Old 09-29-2016, 07:51 AM
Daim's Avatar
Well, more POr15, as my can dried out (seemed a little hole was still in the lid), some copper ease, some nitrile gloves and a partridge in a pear-tree!
Time to assemble that front subframe - at last!
The first of the jobs to finish (without the brakes as I won't be driving the old gal for a few more months).
  #539
Old 09-29-2016, 02:19 PM
Daim's Avatar
Started to POR' it
  #540
Old 09-29-2016, 02:21 PM
Daim's Avatar
The following 5 users liked this post by Daim:
Asdrewq (09-30-2016), BC XJS (09-29-2016), ericjansen (10-01-2016), Greg in France (09-30-2016), warrjon (09-30-2016)
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
