What did you do to or buy for your XJ-S/XJS today?
Old 09-30-2016, 02:10 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
A lovely piece of work Daim, I am dead jealous.
Greg
The following 2 users liked this post by Greg in France:
Daim (09-30-2016), orangeblossom (09-30-2016)
  #542
Old 09-30-2016, 02:27 AM
Asdrewq's Avatar
Mmmm shiny subframe. Hoping to do similar shortly. The one I've found is apparently off a series 3 xj so here's hoping it's the same as the XJS!
What did you prime it with out of interest? I was going to go straight in with a wire brush cleanup & por15 (if I can reopen the tin)
Daim (09-30-2016)
  #543
Old 09-30-2016, 02:55 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Mine is from a Series II XJ6 so all the same...
I had it sandblasted and am applying the POR15 straight to the bare metal. If it was rusty, you'd want a rust convertor to make sure it sticky better.
  #544
Old 09-30-2016, 03:02 AM
Daim's Avatar
Greg
No need to be jealous... No matter how careful you are, you'll get some drops on your skin. That took a week last time to go...
Now I've got to flood the subframe inner with POR15. Just to make sure it stays good (as little rattle can be heard due to some rusting). I don't want to do this again
  #545
Old 09-30-2016, 03:07 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Looks good, and wont rust
  #546
Old 09-30-2016, 02:43 PM
Daim's Avatar
Apart from brakes and springs, the front axle has been rebuilt... Yay! The metric XJ40 fulcrum shafts do the job just as well - and are really low priced!
  #547
Old 10-01-2016, 10:52 AM
Daim's Avatar
Looking good! Just waiting for some threaded rods... Can't get the new springs in otherwise...
The following 3 users liked this post by Daim:
BC XJS (10-01-2016), Doug (10-01-2016), warrjon (10-01-2016)
  #548
Old 10-01-2016, 11:52 AM
Superb job, Daim. Quite outstanding.
Greg
Daim (10-01-2016)
  #549
Old 10-01-2016, 05:54 PM
warrjon's Avatar
Good work Damien
Daim (10-02-2016)
  #550
Old 10-01-2016, 11:07 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
Daim,
I have no any comment, but read (and see) your progress with amazement.
What you are doing is awesome, and will be a lead for me, and I guess others.
My sincere compliments, and keep it coming!
Daim (10-02-2016)
  #551
Old 10-02-2016, 04:29 PM
xjsman89's Avatar
Looking great, Daim! She'll look brand new up front for sure!
  #552
Old 10-05-2016, 06:15 PM
Pwilson45's Avatar
Default Replaced drive belts
Tedious but not impossible.
All 4 belts sourced from NAPA.
Took about 4 hours.
Must access alternator belt from below.
  #553
Old 10-14-2016, 02:59 PM
95 Cat's Avatar
Yesterday, I drained the transmission fluid for the 5th time (to get as much of the old fluid out as possible, dropped the pan and changed the transmission filter. Has 73,000 miles and was a bit overdue (but I only bought it about a month ago).
Seeing what some of you guys do amazes me.
  #554
Old 10-17-2016, 02:21 PM
Steve M's Avatar
Received 2,996 Likes on 1,691 Posts
Went to fit the new FPR today and it won't fit, wrong sized connector.
Not at all chuffed on that one.
Refitted the old one and now running like a bag of spanners.
Even less chuffed on that one.
Swore at it and put it back in the garage.
  #555
Old 10-18-2016, 07:55 PM
chriskindbooks's Avatar
After having a wonderful summer driving, I put the gal away for the long Canadian winter.Checked antifreeze /disconnected battery and filled car/trunk and motor with mothballs. I found that mothballs do discourage the little boogers from building nests.
orangeblossom (10-19-2016)
  #556
Old 10-19-2016, 03:06 AM
orangeblossom's Avatar
Received 3,777 Likes on 2,616 Posts
Hi Chris
It only seems five minutes ago that we were getting our Cars out for the Summer, doesn't the time just seem to fly by.
Except of course in Winter that seems to go on forever.
The following 2 users liked this post by orangeblossom:
chriskindbooks (10-19-2016), Jonathan-W (10-19-2016)
  #557
Old 10-19-2016, 07:38 AM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
Well done Al. As you've found out you really have to do a min of 5 refills if you're to get a decent change of fluid. This is because you can only drain / suck 2.5 litres out of a total of 9 litres. I've recently done four changes with some Dexron II that I had lying around. I now need to change the filter and then I'll do four more changes with Dexron III.
Paul
The following 2 users liked this post by ptjs1:
Jonathan-W (10-19-2016), orangeblossom (10-19-2016)
  #558
Old 10-19-2016, 10:28 AM
Jonathan-W's Avatar
what procedure do you use?
  #559
Old 10-19-2016, 10:42 AM
Daim's Avatar
So, more parts on their way. As it looks I got the last original heatshields for the subframe rubbers... Lucky me
  #560
Old 10-21-2016, 09:15 AM
Daim's Avatar
Seems I missed the last heatshield on one side. Doesn't matter, as I'll have the one I have mirror make to fit the other side. Depending on what they cost, might have both sides then done in stainless steel...
Anyone interested?
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
