What did you do to or buy for your XJ-S/XJS today?
#761
#762
#764
To test the fan itself: a good test is to pull the two leads off the thermostatic switch and join them together (simulating the switch going to "on"). If the fan works, ignition on, the switch is the trouble. If the fan does not work, it is worth just feeding the fan 12 volts from an off-car source (ignition off) to see if it goes OK.
If the fan goes with 12 volts externally applied you have to find the wiring fault. There is a line fuse in the fan wiring clipped on the radtop panel, check that. Also the fuse nearest the front in the under bonnet fuse box on the LHS wing gutter might be bad.
Enough to start with, hope it is useful.
The following 2 users liked this post by Greg in France:
Jonathan-W (05-12-2017),
Stargazer XJS (05-13-2017)
#765
#766
Got my water pump bearing at long last... My cousin in Britain managed to locate probably the last one available (on the planet?).
Compared to my worn bearing, it is like "day and night". Very firm, very little play in the races... No rattles. My V12 should sound like a new car again, at least when it is ready
#767
#768
Have not actually bought them yet as I have just sent the order through and waiting on the total.
Spin on oil filter adapter kit
Air Cleaners
Stainless steel braided oil lines
Hi torque starter motor
Aluminium radiator
Electric fan conversion
Ventilated rear disc rotor kits
Larger directional front rotors
Stainless steel braided brake hoses
Aluminium rear brake calipers
Uprated sway bars
Extractors
Stainless steel exhaust system
Air Cleaners
Aluminium radiator
Uprated sway bars
Extractors
#769
Air Cleaners
Aluminium radiator
Uprated sway bars
Extractors
Air Cleaners
Aluminium radiator
Uprated sway bars
Extractors
#771
The following 3 users liked this post by warrjon:
#772
Most recently, a custom sun-faded/aged new 'ski slope' with cupholders, a used original tan carpet heel pad (my floor carpets made by Paul's Jaguar didn't get one because they no longer have new ones), seat rail extenders (adds height and allows seats to go back further for more leg room for us 6+ foot tall owners), and 4 new head lamps (Wagner 5 3/4). An old XJ6 growler horn button to install somewhere that will look right/proper (I just really like them, they suit the car and the later models didn't have them). Also I got some vinyl silver pin-stripe tape to do the 'headlamp to tail lamp' stripe (it really helps accentuate the main line of the body). Also a set of 1975-80 models stainless wiper arms/frames and a new set of Trico steel refills for them. I think that's everything...
#774
My front pulley came off. I'm gonna put that back on. I need that. You might check yours.
Crankshaft bolt
Compressible collar for the pulley / harmonic balancer
In the "While Im in there" department...
Front crank seal
Distance piece
Spal 185 Fan controller
Deralle 18217 17" dual-speed electric primary fan.
This fan likes amps, but I'm sending the 115 amp alternator back as it's the Bosch, and the shaft is too large for my 75A alt fan and pully. Local shops want way too much to even rebuild it much less rewind it to higher amps. Suggestions? There's an 02 and an 05 X-Type and a 2000 S-Type in the pull-a-part. Anyone know what they have?
Crankshaft bolt
Front crank seal
Distance piece
#775
rgp (08-13-2017)
#776
#777
#780
Jonathan-W (08-15-2017)
